Laguna Posted May 3, 2010 Share Posted May 3, 2010 What should I use inbetwen the polish and the wax? Should I DS the car down and make sure it's buffed good? Use BSG? Use nothing? Also, what do you recommend between wax layers? I'm only going to do it once today and then tomorrow do another layer and that's it... Link to comment Share on other sites More sharing options...
Doug123 Posted May 3, 2010 Share Posted May 3, 2010 nothing between wax layers, I would say. What wax are you using? Just wash and detail spray (and maybe BSG) between those waxing times, and DRIVE it! Link to comment Share on other sites More sharing options...
Team Adam's Posted May 3, 2010 Share Posted May 3, 2010 Key is what products you're using. If MSW or Buttery you can do a wipe down with DS and have no adverse effects, but before a layer of Americana I'd recommend Waterless. In some cases the gloss enhancer in DS doesn't play well with the Americana, generally when they're used close together. BSG isn't like a typical glaze, its a topper instead of a base so always save that as a last step if you intend to use it at all. Link to comment Share on other sites More sharing options...
Laguna Posted May 3, 2010 Author Share Posted May 3, 2010 I'll be using a coat of the Machine Super Wax (machine-applied) and a coat of Pinnacle Sig II (hand-applied). All after using SHR and FMP. Link to comment Share on other sites More sharing options...
Chewy Posted May 3, 2010 Share Posted May 3, 2010 As a DD I'd put (and I will be) 2 coats of MSW on it and then follow it up. Remember to let the MSW off gas for 12-24 hours first. MSW last what seems like forever. Chris Link to comment Share on other sites More sharing options...
Laguna
4 answers to this question
