Pc7424xp
hawaiianstyle
10 answers to this question
The electronic tech in me needs to speak up! LOL
If you are going to replace the cord from the internal connection back, I would suggest replacing the strain relief as well. That's the rubber grommet that extends out of the PC for the first few inches. It helps to prevent the cable from bending too much at the PC, thus protecting the connections themselves.
The trick is that finding a proper strain relief is neigh on impossible, so you need to build one yourself. When I do this at work, I use two to three layers of increasingly larger heat shrink. You start just inside the housing of the tool, in this case the PC, and go out the same distance as the factory version. Doing it in a couple of layers helps to stiffen it up.
Not sure how Porter Cable attaches theirs, so it may even be possible to save the factory grommet.
Jim,
I was able to use the factory grommet.:2thumbs:
