bbster Posted August 14, 2010 Share Posted August 14, 2010 I drove down road that was under construction. Lots of dust on the truck rained that night and some how the dust was cement dust and now I have cement on the paint. Any way to remove.........Feeling really stupid right now Thanks Link to comment Share on other sites More sharing options...
Sooners Posted August 14, 2010 Share Posted August 14, 2010 I would try some WD-40 first, and if that doesn't work, some kerosene should get it off. You'll want to make sure and reapply wax to any of those areas as any wax protectioin will be removed. Link to comment Share on other sites More sharing options...
Chris@Adams Posted August 14, 2010 Share Posted August 14, 2010 Man this could be tricky because of the grit. Try 3m adhesive remover. I would go to a self serve car wash, spray the spots with 3m let set a little bit, then try spraying the grit off of your car with water, repeat if necessary. Just make sure its all off before you wash with Adam's wash pad. Then I would wax. Good luck! Link to comment Share on other sites More sharing options...
bbster Posted August 14, 2010 Author Share Posted August 14, 2010 Thanks guys I will let you know how it turns out Link to comment Share on other sites More sharing options...
bbster Posted August 15, 2010 Author Share Posted August 15, 2010 WD40 did the trick Sprayed it on and let it sit then use a plastic scraper to loosen up the cement. Thanks guys for your help this place is the best Link to comment Share on other sites More sharing options...
Adam Posted August 15, 2010 Share Posted August 15, 2010 I love a success story! Link to comment Share on other sites More sharing options...
bbster
Thanks
5 answers to this question
