what flex
GTO Guy
I thought adam told me his pads would work on a flex?
The 3401 ships with a 5.5" backing plate that is not interchangeable. Our pads currently take a 5.875" backing plate. You CAN use our pads with a flex, but the plate will sit just inside of the guide ring instead of on it. As a result you need to make sure the pad is centered, also we have no long term results on how that effects pad life.
Also if you're working in tight spots the use of a 4" pad on the PC is very handy, I use them on almost every detail I do... not an option on the Flex unfortunately. Not to say its a bad machine, its a very nice tool - but it does have its flaws.
