NEW!! Adam's Ultimate 2 Bucket Wash Kit.
Team Adam's
A little something thats been in the works for those who prefer a hand wash and want to do it the right way :thumbsup:
GETTING READY -
  • Place a Grit Guard Bucket insert in the bottom of each bucket.
  • Fill one of the buckets with just water, approximately 3/4 of the way to the top - this will be your 'rinse bucket'.
  • Place your jumbo wash pad at the bottom of the other bucket and add approximately 3-4oz of Adam's Car Wash Shampoo directly onto the wash pad.
  • Using a heavy stream of water from the hose fill the bucket, making sure to spray into the pad to activate the soap and generate thick lather - this will be your 'soap bucket'.
THE WASH PROCESS -
  • Start at the top of the vehicle and work your way down, soaping up and cleaning one panel at a time.
  • After each panel take your wash pad, dunk it into your rinse bucket, and rub it against the Grit Guard at the bottom to dislodge any dirt or grit.
  • Move the pad to the soap bucket, rubbing it against the grit guard once again, and then return to the vehicle with fresh soapy water.
  • Repeat this process after each panel and complete the entire vehicle EXCEPT for the lowest portion, approximately the lowest 1/4 of the vehicle should be done last.
  • Place your 2nd, smaller, wash pad into the soap bucket. Add another 1-2oz of Car Wash Shampoo and generate fresh suds.
  • Complete the lowest 25% of the car using this pad and the same process outlined earlier, rinsing the pad after each panel.
  • DO NOT rinse the vehicle until all panels are cleaned.
  • Lastly rinse the vehicle using a heavy stream of water from the hose. Make sure to get soap out of all cracks and crevices including side view mirrors and around door handles.
  • If a garage or shady area is available pull the car to that spot at this time.
DRYING -
  • Mist the vehicle with Adam's Detail Spray while still wet.
  • Starting at the top of the vehicle and working your way down use the Adam's Great White Drying Towel to dry.
  • Use additional squirts of Detail Spray in any areas where water is starting to dry and leave spots.
  • Use second included towel in the event the first one becomes too saturated or doesn't absorb anymore water.
  • Dry the entire outside of the car including paint and glass.
  • Save door jambs for last.
  • Use a different towel for drying wheels and tires.
STEP BACK AND ADMIRE, YOU'RE DONE!!
11 answers to this question
