eleven357 Posted January 17, 2009 Share Posted January 17, 2009 Does anyone know how to remove the stock multireg nozzle from a Cam Spray pressure washer? I am trying to figure out how to attach the foamer to the end of the gun, but I can't seem to figure out how to remove the existing nozzle. Link to comment Share on other sites More sharing options...
0 eleven357 Posted January 17, 2009 Author Share Posted January 17, 2009 hahahaha  apparently the pressure washer I bought has chem injection built in already.  I guess I didn't need to order the foamer attachment. Link to comment Share on other sites More sharing options...
0 08G8V8 Posted January 17, 2009 Share Posted January 17, 2009 hahahaha apparently the pressure washer I bought has chem injection built in already.  I guess I didn't need to order the foamer attachment.  The built in injector in the pressure washer does not create thick foam like a foam cannon type of adapter will. Link to comment Share on other sites More sharing options...
0 eleven357 Posted January 17, 2009 Author Share Posted January 17, 2009 The built in injector in the pressure washer does not create thick foam like a foam cannon type of adapter will. Â Ok good. Then I am glad that I bought the attachment. Could you please tell me how to attach the foamer to my wand? I cannot figure out how to take off the existing nozzle at the end of the wand. Thanks! Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted January 17, 2009 Share Posted January 17, 2009 I'm betting Junkman can tell you how to do that, AJ's good at that stuff   WHERE YOU AT JUNKMAN !!!!!!! Link to comment Share on other sites More sharing options...
0 08G8V8 Posted January 17, 2009 Share Posted January 17, 2009 What kind of pressure washer is it, and what is the attachment you bought? Is it a Karcher? Link to comment Share on other sites More sharing options...
0 eleven357 Posted January 17, 2009 Author Share Posted January 17, 2009 (edited) I have a Cam Spray 1000A washer and the Cam Spray Foamer. Â Edited January 17, 2009 by eleven357 Link to comment Share on other sites More sharing options...
0 08G8V8 Posted January 17, 2009 Share Posted January 17, 2009 Check out this link: http://www.autopia.org/forum/car-detailing/98874-foam-cannon-gun-lance-attachment-test.html  Basically, you need to get some quick disconnects, and at the middle of your sprayer install them to allow you to switch between the original wand and the foamer.  I will take some pictures of my cheap Karacher pressure washer setup, using the same foam cannon you have. It's not quite the same, but my nice pressure washer is over at a buddies, and it looks similar to your wand.  Give me a bit, and I will post up a few pics. Link to comment Share on other sites More sharing options...
0 eleven357 Posted January 17, 2009 Author Share Posted January 17, 2009 Check out this link:http://www.autopia.org/forum/car-detailing/98874-foam-cannon-gun-lance-attachment-test.html  Basically, you need to get some quick disconnects, and at the middle of your sprayer install them to allow you to switch between the original wand and the foamer.  I will take some pictures of my cheap Karacher pressure washer setup, using the same foam cannon you have. It's not quite the same, but my nice pressure washer is over at a buddies, and it looks similar to your wand.  Give me a bit, and I will post up a few pics.  Thanks man!!!!!  I really do appreciate all of your help.  I was panicking earlier. Link to comment Share on other sites More sharing options...
0 eleven357 Posted January 17, 2009 Author Share Posted January 17, 2009 Where can I buy these quick disconnects at? Link to comment Share on other sites More sharing options...
0 08G8V8 Posted January 17, 2009 Share Posted January 17, 2009 This is a sort of step by step using various connectors to be able to attach the foamer to the Karcher. You just need to find the various male/male, male/female, female/female type of connectors that will work for you situation. The long adapter on the end is unique to the Karcher. You can get these parts at the same place you linked for your foamer, or at Home Depot/Lowes. I got mine at a garden supply store, for much cheaper than HD/Lowes. Â Â Â Â Â Â Â Â Nitelord and eleven357 2 Link to comment Share on other sites More sharing options...
0 Nitelord Posted January 17, 2009 Share Posted January 17, 2009 Cool sequence of detailed pix. Thanks for taking the time to put that together for us. Link to comment Share on other sites More sharing options...
0 eleven357 Posted January 17, 2009 Author Share Posted January 17, 2009 (edited) Thanks for the photos dude! Â I think I will just take the Foamer and first half of my wand down there to make sure I get the right size parts. Â I found them at lowes and I already have a male quick connect that screws into the foamer attachment. So I just need a female piece that will screw on the end of my wand. Â Â Â Thanks man! Edited January 17, 2009 by eleven357 Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted January 17, 2009 Share Posted January 17, 2009 Nice write up Jeff !!!!! Link to comment Share on other sites More sharing options...
0 08G8V8 Posted January 17, 2009 Share Posted January 17, 2009 No problem. Glad to do it. Â I have a few extra pieces so that I can make it work for both pressure washers that I have. I have a nicer 2550 psi pressure washer, and this cheap 1500 psi Karcher pressure washer. Â I figured 1500 psi would be safer, and it was only $70 bucks at Big Lots one weekend, so I figured I couldn't go wrong with it. Link to comment Share on other sites More sharing options...
0 jjwvette Posted January 17, 2009 Share Posted January 17, 2009 I think I need one of them Link to comment Share on other sites More sharing options...
0 eleven357 Posted January 17, 2009 Author Share Posted January 17, 2009 (edited) Ok so I went down to Lowe's and Home Depot to find some quick connects that would fit my wand to no avail. So I am going to show you guys some pics to see if you guys are seeing something that I'm not. Â Click on the images for a larger view Edited January 17, 2009 by eleven357 Link to comment Share on other sites More sharing options...
0 08G8V8 Posted January 18, 2009 Share Posted January 18, 2009 Can you post a closeup of the end of the sprayer end? Link to comment Share on other sites More sharing options...
0 eleven357 Posted January 18, 2009 Author Share Posted January 18, 2009 Can you post a closeup of the end of the sprayer end? End of the wand? or end of the foamer? Link to comment Share on other sites More sharing options...
0 08G8V8 Posted January 18, 2009 Share Posted January 18, 2009 Split the pressure washer sprayer into (2) pieces and take a detail closeup of both ends. I think the pictures you posted before were showing a clear view of the tip. I need to see the mating connection of the trigger portion. Link to comment Share on other sites More sharing options...
0 eleven357 Posted January 18, 2009 Author Share Posted January 18, 2009 Split the pressure washer sprayer into (2) pieces and take a detail closeup of both ends. I think the pictures you posted before were showing a clear view of the tip. I need to see the mating connection of the trigger portion. Ok will do! Link to comment Share on other sites More sharing options...
0 eleven357 Posted January 18, 2009 Author Share Posted January 18, 2009 trigger side of wand: Â wand extension side: Link to comment Share on other sites More sharing options...
0 eleven357 Posted January 18, 2009 Author Share Posted January 18, 2009 here is a different shot: Link to comment Share on other sites More sharing options...
0 08G8V8 Posted January 18, 2009 Share Posted January 18, 2009 Chris, the problem is the way the wand connects to the trigger. I have spent some time trying to come up with an easy solution, but can't seem to find one. What I would suggest is getting a new gun/wand with solid brass connections at the splice. This would allow you to easily use brass quick disconnects. Â You could get just a new wand to replace the one you have. Then, if you bought a female/female connector to attach to your existing male threaded end of your trigger and then use quick disconnects similar to the pictures I posted earlier. Â The female threaded portion of your tip, with the inset brass fitting, doesn't allow for any connector to be inserted. I was going to say un-thread that brass connector and get a male connector to thread into the plastic outer female threads, but I don't know how well it would hold up to the pressure. You could try it. Â Does this make any sense? Link to comment Share on other sites More sharing options...
0 eleven357 Posted January 18, 2009 Author Share Posted January 18, 2009 Chris, the problem is the way the wand connects to the trigger. I have spent some time trying to come up with an easy solution, but can't seem to find one. What I would suggest is getting a new gun/wand with solid brass connections at the splice. This would allow you to easily use brass quick disconnects. You could get just a new wand to replace the one you have. Then, if you bought a female/female connector to attach to your existing male threaded end of your trigger and then use quick disconnects similar to the pictures I posted earlier.  The female threaded portion of your tip, with the inset brass fitting, doesn't allow for any connector to be inserted. I was going to say un-thread that brass connector and get a male connector to thread into the plastic outer female threads, but I don't know how well it would hold up to the pressure. You could try it.  Does this make any sense?  Yeah that makes sense.  How much do you think a new wand would be?  Can you recommend one that you know positively will work?  Thanks for all the help!  I really do appreciate your kindness. Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted January 18, 2009 Share Posted January 18, 2009 I'd bring the foam gun to HomeDepot with me and try to piece it together there :thumbsup: Link to comment Share on other sites More sharing options...
eleven357
Top Posters For This Question
36
20
12
8
Popular Days
Jan 18
33
Jan 17
17
Jan 19
15
Jan 21
4
eleven357 36 posts
08G8V8 20 posts
rwisejr 12 posts
Bill-V8V 8 posts
Popular Days
Jan 18 2009
Jan 17 2009
Jan 19 2009
Jan 21 2009
Popular Posts
08G8V8
Posted Images
78 answers to this question
