Barefootpr Posted May 14, 2019 Share Posted May 14, 2019 The dryer working on 15 amps or 20 amps the plugs on the wall. Sorry for my bad English I am French Canadian. thanks for replying Link to comment Share on other sites More sharing options...
GXPaycheck Posted May 15, 2019 Share Posted May 15, 2019 (edited) Should work with a 20 amp circuit breaker. Adams folks can verify. Edited May 15, 2019 by GXPaycheck Corrected by The Wolf Link to comment Share on other sites More sharing options...
TheWolf Posted May 15, 2019 Share Posted May 15, 2019 21 hours ago, Barefootpr said: The dryer working on 15 amps or 20 amps the plugs on the wall. Sorry for my bad English I am French Canadian. thanks for replying The power rating is 2000W at full speed, which would require a 20A circuit. The unit has been tested on 15A circuits and has run fine, but can also trip the circuit at full speed. This also depends on what other electrical loads are on the circuit. If you only have one 15A circuit available, and the garage lights or other loads are also on this circuit, then you would likley have an issue. If it is not possible to have a larger 20A circuit, or you have issues with tripping a 15A circuit, then you would have to run the blower a little slower to not draw as much power. Being able to dial down the speed, and power draw, on the Air Cannon is an advantage over other blowers that only have one speed and required a 20A circuit. Link to comment Share on other sites More sharing options...
