02 Regular Cab Chevy truck build
tony.steve
Posted
Finally finished my build on my truck.
4 8" kicker cvr's
kicker z750.1
kicker zx200.2
kicker ks components in front
rear speakers unhooked.
alpine cda-105
dynamat in the doors and kicker wiring.
Box measurements are .4 per sub after displacement. Sounds small but it hits the requirements of what the subs ask for.
everything removed
zx750.1 mounted under passenger seat. barely visible unless seat is all the way up.
box finished. wrapped in vinyl that I found at a local upholstery shop. matches interior quite well.
My buddy dusty mounting subs. Box is mounted to the back wall of the truck.
Sorry about the blur. Bass knob mounted on empty spot on dash. analog audio in adapter added to the alpine and flush mounted on the dash as well.
Finished
I have had the components installed for quite sometime so I didnt get pics of the installed but they are in the factory position. zx200.2 is mounted under drivers seat.
Over all I am very pleased with the set up. Doesn't hit the low lows like I would like but they are 8's in small boxes. I added the polyfil to the box to help but you can only do so much in the space provided. I will be replacing the cda-105 with something with more control or I will just upgrade to the imprint system for the headunit.
Posted
very nice sir, thats gunna be loud for a truck cab! my buddy has a setup similar but only 3. There was a ton more room but I had 2-10" MTX in a custom box in my escalade before I got my SRT, now gunna have a custom fab in the trunk wall somehow of the jeep cause i miss it. Thats not a ported box is it? great execution man!
Posted
No not ported. Didn't have room for a ported box. Its definitely respectable considering its 8s in small boxes. If you notice I ran 1/0ga wire to the distribution blocks then 4 and 8 ga to the amps. I went with 1/0 because I might upgrade to a beefy ten and a bigger amp in the future.
But thanks I sure like it considering the little amount of money I have in it.
If anyone sees me in the North west arkansas area and wants to hear it flag me down.
Posted
I did see that, good choice. You are definitely going to be bumping with that setup in the small cab, gotta make a video of it ;)
