SHINEY HINEY Posted July 30, 2012 Share Posted July 30, 2012 I just got a electric power washer and it wont suck the water through the hose to supply the washer from my 55 gal tank...so I hoping someone would have some info on what kind of pump I could hook up(on the cheap) to make it work..like psi ,gpm that kinda thing.. Link to comment Share on other sites More sharing options...
Fat Mike Posted July 31, 2012 Share Posted July 31, 2012 What is the output of your pressure washer? Some of the electric models are relatively low gpm - in the range of 2 - 4 gpm. You will need a flow rate that matches or better yet, slightly exceeds the flow rate of your pressure washer. You might be able to purchase a sufficiently large pump to meet your needs at a farm / fleet store or perhaps even a camper supply store. Link to comment Share on other sites More sharing options...
3PedalMINI Posted July 31, 2012 Share Posted July 31, 2012 You need a shallow well ( bladder pump), it shuts off the pump as soon as you depress the trigger on the hose it also turns it on as soon as you press the trigger. Most output between 55-85 gpm which is normal household pressure. I designed and built a detailing trailer for someone so I know the ins and outs of one Here's the one I used, worked like a champ, especially with a gas pressure washer. Is your trailer open or closed? If its open make sure you cover this! 1 Horsepower Shallow Well Pump with Stainless Steel Housing Link to comment Share on other sites More sharing options...
SHINEY HINEY Posted July 31, 2012 Author Share Posted July 31, 2012 It's a 1500 psi at 1.3 gpm ..The little cheapy from harbor freight to get me off the ground.. thanks guys:rockon: Link to comment Share on other sites More sharing options...
