bagged00 Posted December 1, 2016 Share Posted December 1, 2016 Can someone tell me some differences between the 3401 and swirl killer? Just curious on things like function vibration noise etc in comparison to the flex Link to comment Share on other sites More sharing options...
0 Dwhite0960 Posted December 1, 2016 Share Posted December 1, 2016 The flex will have more noise present in comparison if the sk is anything like other long throws. The flex will work you more than the long throws will over time as well. The flex won't stall on curves due to the gear driven technology but once you get used to a long throw this is a non issue. I don't own a flex myself but people either love them or hate them if you ask me from what I have seen. Link to comment Share on other sites More sharing options...
0 PostalTwo Posted December 1, 2016 Share Posted December 1, 2016 Flex 8mm throw forced rotation Swirl killer 15 mm free floating spindle The swirl killer is likely smoother the flex is more expensive but likely corrects faster. Also the flex will walk u around if the pad is not perfectly flat . The swirl killer will get pad stall in the curves. It's really hard to compare those two because there so different. If your a hobbyist the swirl killer will be all your likely gonna need. For me comfort was priority 1. So the flex was out due to the forced rotation. Antv20 1 Link to comment Share on other sites More sharing options...
bagged00
2 answers to this question
