So I recently got my Adams foam cannon and pressure washer. I searched the forums for the recommended PW, many suggested the Ryobi so I purchased the 2,000 psi model. After getting everything hooked up I gave it a whirl and unfortunately I was sadly disappointed. My foam gun is nearly the same. I am looking for the thick, shaving cream I have seen but mine is not doing that. The only time I was happy with the foam coming out was when the canister was about to run out, the last few seconds made great foam. I tried the whole process again and same thing, runny watery foam until the last little bit then for a couple seconds it was good. I have checked the clear hose inside and its connected and I have adjusted the valve as well. Still no thick foam. Please someone give me some good advice on how to make this work better and create some thick foam. Thanks in advance...
M3Eric
12 answers to this question
