JJ1o87 Posted May 20, 2010 Share Posted May 20, 2010 Hey guys/girl, I've changed my oil on the Challenger before, but last time I did it I put the entire car on jack-stands. Now this is quite the pain in rump, so I was wondering if it really makes a difference if I just jack up the front of the car. As long as all the oil comes out I'll be a happy Jeff. I just don't know if the incline will make a difference. Many thanks. You're all aces in my book. Link to comment Share on other sites More sharing options...
CorvZ061 Posted May 20, 2010 Share Posted May 20, 2010 Where is the drain plug on the pan? If it's at the back of the pan, sure no problem go ahead and just lift the front, but if it's on the side of the pan I would lift the whole car. Link to comment Share on other sites More sharing options...
JJ1o87 Posted May 20, 2010 Author Share Posted May 20, 2010 Rear of the pan Link to comment Share on other sites More sharing options...
fdresq4 Posted May 20, 2010 Share Posted May 20, 2010 Jeff, Can you use ramps? I have two vehicles that require me to get them in the air a bit. Both have the drain pugs in the rear of the pan. I just pull them up on the ramps and that is all she wrote. My one car is a Saab and has a front air dam/spoiler and it does not hit. They do make ramps for vehicles with a low front clearence. Steve Link to comment Share on other sites More sharing options...
JJ1o87 Posted May 20, 2010 Author Share Posted May 20, 2010 Jeff, Can you use ramps? I have two vehicles that require me to get them in the air a bit. Both have the drain pugs in the rear of the pan. I just pull them up on the ramps and that is all she wrote. My one car is a Saab and has a front air dam/spoiler and it does not hit. They do make ramps for vehicles with a low front clearence. Steve I have ramps in my garage, but they're not wide enough for my tires. My car is also lowered too, so I'm not sure if that would work. I usually drive the car on a piece of wood so I can clear the jack lol Link to comment Share on other sites More sharing options...
turbohcar Posted May 20, 2010 Share Posted May 20, 2010 You only need to raise the front. Jack it up, drain oil, put plug back in, change the filter ( I usually put some oil in the filter before reinstallation), lower car, and fill with oil. Start it up, let idle and turn off, and check oil level. Don't forget to make a new mileage sticker as well. Any questions just ask. Link to comment Share on other sites More sharing options...
coolth Posted May 20, 2010 Share Posted May 20, 2010 i jack the car up then after i pull the plug out, let the jack back down. Make sure the oil pan is in place. Link to comment Share on other sites More sharing options...
Chris@Adams Posted May 20, 2010 Share Posted May 20, 2010 Jeff, I always just raise the front of the car,if the car is warmed up it will drain quick.Check these ramps out. www.raceramps.com They are for lower cars. A friend of mine just bought some for his ZO6 He said they work great! Link to comment Share on other sites More sharing options...
6spdg37s Posted May 21, 2010 Share Posted May 21, 2010 i jack the car up then after i pull the plug out, let the jack back down. Make sure the oil pan is in place. this spells disaester for jeff when his 2-ton muscle car's oil pan, crushes his oil drain pan and he yet again has 9 qts of oil all over his garage floor... this will make for the 5th top video of jeffs security cameras.. Hey guys/girl, I've changed my oil on the Challenger before, but last time I did it I put the entire car on jack-stands. Now this is quite the pain in rump, so I was wondering if it really makes a difference if I just jack up the front of the car. As long as all the oil comes out I'll be a happy Jeff. I just don't know if the incline will make a difference. Many thanks. You're all aces in my book. when i had the viper i only jacked up the front... should work fine... Link to comment Share on other sites More sharing options...
JJ1o87 Posted May 21, 2010 Author Share Posted May 21, 2010 Thanks for the responses! P.S. John it's always convenient of you to be "busy" when I need assistance but when you need assistence the world has to stop. Link to comment Share on other sites More sharing options...
