Bryman312 Posted April 30, 2018 Share Posted April 30, 2018 im thinking of picking up THIS Ryobi pressure washer. my question is this, can i get the Adams snub nose attachment to work with it? or will i just have to use the foam cannon with the Ryobi longer wand? it looks like the hose is threaded but the wand is quick connect. Link to comment Share on other sites More sharing options...
0 SVillalon Posted April 30, 2018 Share Posted April 30, 2018 (edited) the nozzle looks like it comes off with a quick disconnect. You can still use Adams Snub nose, however you will need to buy the adaptor for the hose to connect to the MaleQuick Disconnect on adams snub nose. Edit* at $100 it's not bad. I have a greenworks 1700 psi 1.2 gpm, but now thinking about getting a "better" pressure washer. If you are looking for the shaving foam tendency then you may want to look for a pressure washer with a higher GPM such as 2.0 and up and not the PSI. If you do go ahead with the one you have and still want the Shaving foam from the foam cannon just change the Orifice on the Foam cannon to a 1.1mm orifice. Edited April 30, 2018 by SVillalon Bryman312 1 Link to comment Share on other sites More sharing options...
0 Bryman312 Posted April 30, 2018 Author Share Posted April 30, 2018 11 hours ago, SVillalon said: the nozzle looks like it comes off with a quick disconnect. You can still use Adams Snub nose, however you will need to buy the adaptor for the hose to connect to the MaleQuick Disconnect on adams snub nose. Edit* at $100 it's not bad. I have a greenworks 1700 psi 1.2 gpm, but now thinking about getting a "better" pressure washer. If you are looking for the shaving foam tendency then you may want to look for a pressure washer with a higher GPM such as 2.0 and up and not the PSI. If you do go ahead with the one you have and still want the Shaving foam from the foam cannon just change the Orifice on the Foam cannon to a 1.1mm orifice. thanks for the heads up i actually came across a 1.1 orifice late last night too! Link to comment Share on other sites More sharing options...
0 Red Rambler Posted April 30, 2018 Share Posted April 30, 2018 I have this exact Ryobi pressure washer in question, works well and I have quick connects at the pump and both ends of the hose. Its a quick setup. I concur @SVillalon that if you are looking for shaving cream consistency than do as has been suggested. It honestly works well for what it is, its light weight and easy to setup. I have a higher PSI gas unit, but its not as quick to move/setup so this is a happy medium. Bryman312 1 Link to comment Share on other sites More sharing options...
0 Bryman312 Posted April 30, 2018 Author Share Posted April 30, 2018 thanks guys!! figure ill get these items along with it...... unless you have any reasons something is better/cheaper? female coupling hose coupling 50' hose already has male & female couplings Link to comment Share on other sites More sharing options...
0 pirahnah3 Posted May 1, 2018 Share Posted May 1, 2018 honestly I like the Ryobi ones, we have the larger electric one at work with the hose reel and it works well for us. Bryman312 1 Link to comment Share on other sites More sharing options...
0 Bryman312 Posted May 8, 2018 Author Share Posted May 8, 2018 thanks guys......got the washer on Friday, got all my QC fittings, actually came across a slightly longer (25') hose, my foam cannon should be here any day now (its coming with the 1.1 orifice also) so i hope to be foaming by Monday! ill have to take a day to get all the hard water off my car first, damn city water sprinklers!! then ill foam er down, give it a good waxing too!! Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted May 8, 2018 Share Posted May 8, 2018 On 4/30/2018 at 11:03 AM, Bryman312 said: thanks for the heads up i actually came across a 1.1 orifice late last night too! Where did you find it? Link to comment Share on other sites More sharing options...
0 Bryman312 Posted May 8, 2018 Author Share Posted May 8, 2018 3 hours ago, GXPaycheck said: Where did you find it? HERE YOU GO Link to comment Share on other sites More sharing options...
Bryman312
8 answers to this question
