So after many weeks of building my Adam's collection, I have everything I need and have completed all the detailing steps except for polishing and waxing. Today after work I plan to start on the hood of my black Camaro with a goal of about 95% perfection. Since the hood has very minor damage, I plan to start with the white pad and FMP to see if there is any need to step up to the orange pad and the SHR.
My planned process on a small test area first is:
Spritz of DS, apply 3 peas sized drops to pad, dab product around area and spread in using PC at speed of 1-2, work product horz and vert on speed of 5 until its glazed over and greasy looking with just enough pressure to slow the PC down, then another spritz of DS, continue working product at speed 5 until clear again, remove with polishing towel and inspect results.
My question is: if I havent acheived 95% perfection with this process say after 3 passes, is it safe to say I need to step up to the orange pad and SHR and start over, then return to the white pad and FMP? If I do step up to the SHR, do I inspect the results before moving on to FMP? I know the SHR will create its own damage and I dont want to see that damage as a sign to keep using SHR when its really a sign that only FMP is needed to correct it. Hopefully that makes sense..
I will post before and after pics of the areas that are noticably swirled as I go through the process, I plan to do one major area each night and hopefully be done by the weekend.
camaro2ssblack
4 answers to this question
