hslager69 Posted April 9, 2011 Share Posted April 9, 2011 I was planning to claybar my car tomorrow (first time using clay),i forgot to pickup some dawn dishsoap .How important is that step? Link to comment Share on other sites More sharing options...
MAYBEN Posted April 9, 2011 Share Posted April 9, 2011 if you have wax on the car pretty important.. but you can also use 'rubbing' alcohol diluted into water.. after you wash the car with reg car wash, you can then do a simple mist and wipe to strip any leftover wax residues previously on the car... Link to comment Share on other sites More sharing options...
1anonly Posted April 9, 2011 Share Posted April 9, 2011 if you have wax on the car pretty important.. but you can also use 'rubbing' alcohol diluted into water.. after you wash the car with reg car wash, you can then do a simple mist and wipe to strip any leftover wax residues previously on the car... Someone has been learning Do what he says. If you don't the clay will strip the wax, but you will just clog up the clay faster. Link to comment Share on other sites More sharing options...
MAYBEN Posted April 9, 2011 Share Posted April 9, 2011 Now I just need to actually do it lol Link to comment Share on other sites More sharing options...
Bill-V8V Posted April 9, 2011 Share Posted April 9, 2011 Also keep in mind Dawn shouldn't be used often, it is for once or twice a year if you want to strip the paint. It can dry out any plastic trim you may have. Link to comment Share on other sites More sharing options...
Kingsford Posted April 9, 2011 Share Posted April 9, 2011 Also keep in mind Dawn shouldn't be used often, it is for once or twice a year if you want to strip the paint. It can dry out any plastic trim you may have. If you use dawn and go over the plastic with SVRT you will notice it like soaks it up like no other! I'm going to try the rubbing alcohol this year. Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted April 9, 2011 Share Posted April 9, 2011 Someone has been learning Do what he says. If you don't the clay will strip the wax, but you will just clog up the clay faster. He should be learning. Hes on here more than I am and in a 2 month period he has over 500 posts! Link to comment Share on other sites More sharing options...
hslager69 Posted April 9, 2011 Author Share Posted April 9, 2011 Thanks guys ,I don't have rubbing alcohol either so i might just give her a once over with detail spray and leave the claying until i get some dawn. guess i will change the oil & filter and do some other maintenance for now. Link to comment Share on other sites More sharing options...
DanFish Posted April 9, 2011 Share Posted April 9, 2011 I'm about to head out to do some polishing this morning also, I thought claying the paint would also remove wax making a strip wash not completely necessary? Link to comment Share on other sites More sharing options...
Chewy Posted April 9, 2011 Share Posted April 9, 2011 I'm about to head out to do some polishing this morning also, I thought claying the paint would also remove wax making a strip wash not completely necessary? You're right, it will. Striping it with dawn or isopropyl alcohol helps get areas the clay may miss. If you wash your cars in a coin-op during the winter, the soap there will do a pretty good job of removing your wax over the course of the winter too. Sent from my iPad using special algorithms and data nodes. Link to comment Share on other sites More sharing options...
DanFish Posted April 9, 2011 Share Posted April 9, 2011 You're right, it will. Striping it with dawn or isopropyl alcohol helps get areas the clay may miss. If you wash your cars in a coin-op during the winter, the soap there will do a pretty good job of removing your wax over the course of the winter too. Sent from my iPad using special algorithms and data nodes. Gotcha! Thanks Chris! Link to comment Share on other sites More sharing options...
MAYBEN Posted April 9, 2011 Share Posted April 9, 2011 He should be learning. Hes on here more than I am and in a 2 month period he has over 500 posts! I've been a member for a while.. saw the light more recent.. being unemployed doesnt help lol Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted April 9, 2011 Share Posted April 9, 2011 Hey no worries, im employed and spend more time on the forum then I do on my work! Link to comment Share on other sites More sharing options...
MAYBEN Posted April 9, 2011 Share Posted April 9, 2011 lol I've been a member longer than you, nanner nanner nanner Link to comment Share on other sites More sharing options...
Chris@Adams Posted April 9, 2011 Share Posted April 9, 2011 Have fun Harry, keep us updated on your progress! Link to comment Share on other sites More sharing options...
hslager69
14 answers to this question
