jpu471 Posted August 15, 2011 Share Posted August 15, 2011 For the first time I got what I think are holograms after using the Flex,possible? If so what would have caused this I moved the machine at a good speed, something else. They came out with the Porter Cable. Thanks Link to comment Share on other sites More sharing options...
Chewy Posted August 15, 2011 Share Posted August 15, 2011 Hmm... Weird... We're you making sure you kept the pad as flat as possible? I would believe that you may be able to see issues if you were running it with the pad on the edge, but I've never had an issue with holograms on my vehicles yet. How fast were you moving it around? No faster than what Adam shows, right? Chris Link to comment Share on other sites More sharing options...
DaveVY Posted August 15, 2011 Share Posted August 15, 2011 Link to comment Share on other sites More sharing options...
jpu471 Posted August 15, 2011 Author Share Posted August 15, 2011 Maybe they weren't holograms,just mar marks. Saw them after I had wiped off the polish. Speed was correct so maybe the pad wasn't always flat. One difficultly I have is since I have to do the polishing in the day outside the pads tend to dry quick especially with the Flex I use a lot of DS Link to comment Share on other sites More sharing options...
Chewy Posted August 15, 2011 Share Posted August 15, 2011 The forced rotation is another reason why they dry out so quickly. No garage? An EZ-UP canopy may help too. Chris Link to comment Share on other sites More sharing options...
jpu471 Posted August 15, 2011 Author Share Posted August 15, 2011 Single lane street on a windy hill, could be interesting as the canopy goes sailing off:) Link to comment Share on other sites More sharing options...
Chris@Adams Posted August 15, 2011 Share Posted August 15, 2011 For the first time I got what I think are holograms after using the Flex,possible? If so what would have caused this I moved the machine at a good speed, something else. They came out with the Porter Cable. Thanks I don't think that it could be possible. Did you do White Pad & FMP with the Flex? Link to comment Share on other sites More sharing options...
jpu471 Posted August 16, 2011 Author Share Posted August 16, 2011 Yes Link to comment Share on other sites More sharing options...
1anonly Posted August 17, 2011 Share Posted August 17, 2011 Ken, I know what you're talking about and know what it's from. FMP is very oily and if it is not work long enough will leave what looks to be holograms. Here's one way to fix it. (Hopefully Dylan will correct me if I put the incorrect speed down.) Take your PC with gray pad and Revive on speed 3. Do a pass and wipe off. Or you can do it by hand. I do it by hand and it works. Link to comment Share on other sites More sharing options...
Wardo Posted August 17, 2011 Share Posted August 17, 2011 Ken, I know what you're talking about and know what it's from. FMP is very oily and if it is not work long enough will leave what looks to be holograms. Here's one way to fix it. (Hopefully Dylan will correct me if I put the incorrect speed down.) Take your PC with gray pad and Revive on speed 3. Do a pass and wipe off. Or you can do it by hand. I do it by hand and it works. good to know. i agree about the oiliness. Link to comment Share on other sites More sharing options...
THE Mook Posted August 17, 2011 Share Posted August 17, 2011 Revive is a GREAT way to get some of that up. Although, do you have any pictures of what you are talking about? Link to comment Share on other sites More sharing options...
Chewy Posted August 17, 2011 Share Posted August 17, 2011 If it truly is the oiliness which I too have seen, it comes of with WW and the corresponding towel. Chris Link to comment Share on other sites More sharing options...
jpu471 Posted August 18, 2011 Author Share Posted August 18, 2011 Thanks guys I got it off by using the PC and FMP Link to comment Share on other sites More sharing options...
jpu471
12 answers to this question
