txredgt Posted October 18, 2011 Posted October 18, 2011 I almost posted this on a mustang forum but I figure this would be the much better place! I am about to upgrade the front brake calipers/rotors and I am looking for some input on what is the longest lasting finish for the calipers? Powdercoating or painting with the high temp paint are the only options I think but I am open if there are any others. As far as the goodies I am thinking about 13" rotors and I am not sure if I will go with slotted and vented or what exactly. This is the kit I am considering: 1994-04 Mustang SVE 13" Cobra Style Front Brake Kit at LRS - Same Day Shipping! Any ideas? Looks like cost wise I will be around 500 or so but I am also considering piecing it together myself because my personal tastes is that the red color in that pic together with the 'sve' logo is not something I prefer, and if I am going to spend good money on it I want it to look just as good. This is the option for piecing it together myself: 1994-2004 Mustang Bullitt Front Brake Calipers - Pair - 1994-2004 - Brakes & Calipers - Home for your Ford Mustang Opinions? Thoughts?
Marylander Posted October 18, 2011 Posted October 18, 2011 I've had good, long lasting results with the duplicolor kits from the parts store and also from good old rustoleum. The big key is starting with a clean surface, so you should be just fine.
THE Mook Posted October 18, 2011 Posted October 18, 2011 G2 Caliper paint is by far the best of the paint choices out there, given what I have seen from the other 2 or 3 brands. I believe Powdercoating will probably give you better longevity. Although I have had my caliper paint on for almost 18 mos or more now and it seems to be looking just as newas when I did them!
Chris@Adams Posted October 18, 2011 Posted October 18, 2011 I've had good, long lasting results with the duplicolor kits from the parts store and also from good old rustoleum. The big key is starting with a clean surface, so you should be just fine. I have too with Duplicolor!
Hillmizzle Posted October 18, 2011 Posted October 18, 2011 Powdercoating would definately be the best choice (also the most expensive), they have high temp coatings as well. Unless you track your vehicle (road course) I doubt you will generate enough heat to fade your colors. So with that said all options are good options for a DD vehicle. Sent from my Droid using Tapatalk
