bigred vette Posted December 24, 2008 Share Posted December 24, 2008 Since the Gen2 pads are considerably bigger then the gen1 pads, should i move the speed up a little to make up for more of that rotating mass? Link to comment Share on other sites More sharing options...
0 Nitelord Posted December 24, 2008 Share Posted December 24, 2008 I don't think an increase in speed is needed. The PC doesn't care about the difference on pad size. Once it's up to speed, I don't think it's working any harder with the larger pads. I would think business as usual. Use the same technique you did before, just cover a little more ground is all. IMHO... I'm not an engineer, so I could be mistaken. :pc: Link to comment Share on other sites More sharing options...
0 bigred vette Posted December 24, 2008 Author Share Posted December 24, 2008 Thanks for the info! Link to comment Share on other sites More sharing options...
0 bigred vette Posted December 25, 2008 Author Share Posted December 25, 2008 for anyone elses opinion Link to comment Share on other sites More sharing options...
0 GerryC Posted December 26, 2008 Share Posted December 26, 2008 I don't think an increase in speed would be necessary because while the Gen2 pads have a larger diameter, the Gen1 pads are thicker. Link to comment Share on other sites More sharing options...
0 jjwvette Posted December 26, 2008 Share Posted December 26, 2008 What does Jason think? Link to comment Share on other sites More sharing options...
0 JJ1o87 Posted December 28, 2008 Share Posted December 28, 2008 What speed are you using now? I'm about to order my porter cable and machine stuff and haven't a clue what speed I should be using. Link to comment Share on other sites More sharing options...
0 Adam Posted December 28, 2008 Share Posted December 28, 2008 Hi Brian- I typically use the PC with the Gen2 pads at the following speeds: Swirl & Haze, removing moderate swirls with the orange Swirl Killer Pad: 5-6 Fine Machine Polish w/ white Fine Polish Pad: 5 Machine SuperWax w/ black Waxing Pad: 3-4 Using adequate pressure and speed it key to getting desired results, and stay tuned for a new video, being edited now! Thanks, and post additional questions and I'll answer quick! Link to comment Share on other sites More sharing options...
0 bigred vette Posted December 28, 2008 Author Share Posted December 28, 2008 Hi Brian- I typically use the PC with the Gen2 pads at the following speeds: Swirl & Haze, removing moderate swirls with the orange Swirl Killer Pad: 5-6 Fine Machine Polish w/ white Fine Polish Pad: 5 Machine SuperWax w/ black Waxing Pad: 3-4 Using adequate pressure and speed it key to getting desired results, and stay tuned for a new video, being edited now! Thanks, and post additional questions and I'll answer quick! thanks Adam, ive just been using what speed it says on the bottle, i dont remember what they are right now but ill be using what you just told me. Link to comment Share on other sites More sharing options...
0 Adam Posted December 28, 2008 Share Posted December 28, 2008 Everything is a work in progress Brian, and I'm learning as much from customers as we are teaching. As soon as we feel like we have a solution, we try something new, and 'WALLA' it's better with a slightly different process or chemical! That's life, and the best stuff and process on earth is only the best for a few minutes, before it's improved again. Link to comment Share on other sites More sharing options...
bigred vette
9 answers to this question
