ChargerMatt Posted August 12, 2012 Share Posted August 12, 2012 (edited) Closed. Edited August 19, 2012 by ChargerMatt Link to comment Share on other sites More sharing options...
Kenneth Posted August 12, 2012 Share Posted August 12, 2012 Will this work for my hemi ram? Link to comment Share on other sites More sharing options...
ChargerMatt Posted August 12, 2012 Author Share Posted August 12, 2012 Will this work for my hemi ram? It will only work for the 3.5L v6 unfortunately. Link to comment Share on other sites More sharing options...
Skywalker Posted August 12, 2012 Share Posted August 12, 2012 Will this work for my hemi ram? It will work fine, the mounting is different for the v6 and v8 though. If you could fabricate a bracket or find a hole then you can make it work. I used the v6 bracket like Matt has to mount a Catch Can to my Avenger, I just had to find a spot Link to comment Share on other sites More sharing options...
Blue04SSS Posted August 13, 2012 Share Posted August 13, 2012 A catch can should work on any car/truck and any motor. The difference comes with the mounting bracket Link to comment Share on other sites More sharing options...
ChargerMatt Posted August 13, 2012 Author Share Posted August 13, 2012 A catch can should work on any car/truck and any motor. The difference comes with the mounting bracket I thought the intake and exit valve sizes were different on the catch can itself? Link to comment Share on other sites More sharing options...
Blue04SSS Posted August 13, 2012 Share Posted August 13, 2012 A catch can filters the vapors to seperate the oil out of the air. Most of the time it brings the air into it and it runs through a metal mesh to catch the oil. Im guessing you are talking about the fittings not actual valves. Inlet and outlets are different on some catch cans for how the air flows to catch the oil. Link to comment Share on other sites More sharing options...
ChargerMatt Posted August 13, 2012 Author Share Posted August 13, 2012 A catch can filters the vapors to seperate the oil out of the air. Most of the time it brings the air into it and it runs through a metal mesh to catch the oil. Im guessing you are talking about the fittings not actual valves. Inlet and outlets are different on some catch cans for how the air flows to catch the oil. I'm really just going off what I've heard. I'm not very mechanically inclined at ALL, hence why this hasn't been installed yet Link to comment Share on other sites More sharing options...
