technologic Posted August 15, 2012 Share Posted August 15, 2012 I usually have rubber on my paint after track events from pieces of rubber hitting my paint at high speed. Is there a faster procedure than using clay, sometimes it can take a bit to remove. Link to comment Share on other sites More sharing options...
Team Adam's Posted August 15, 2012 Share Posted August 15, 2012 I've found that using a pressure washer to knock the bulk of it off is very effective, but theres still always some claying left to be done. Link to comment Share on other sites More sharing options...
technologic Posted August 15, 2012 Author Share Posted August 15, 2012 I need to get my gun fixed for my Honda Pressure Washer, somethings up with the nozzle where it attaches to the gun, it leaks. Sometimes with only using clay I can rub and rub for a bit before the rubber comes off, it's kind of tedious. Would it hurt to go over the rubber with an orange pad using my PC? Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted August 16, 2012 Share Posted August 16, 2012 I need to get my gun fixed for my Honda Pressure Washer, somethings up with the nozzle where it attaches to the gun, it leaks. Sometimes with only using clay I can rub and rub for a bit before the rubber comes off, it's kind of tedious. Would it hurt to go over the rubber with an orange pad using my PC? Try replacing the rubber gasket. It might be broken or out of place Link to comment Share on other sites More sharing options...
Chewy Posted August 16, 2012 Share Posted August 16, 2012 Before hitting the track, coat the area with really cheap paste wax like Turtle Wax. The goal is to have the crust on there. Then pressure wash it all off when done hit with some alcohol to remove the TW and put a coat of quality Adams on there. If this is happening because of other cars, then you're SOL. You have to do like you're doing. My method is to keep YOUR rubber or the rubber from the track off of the sides or front of the car. Link to comment Share on other sites More sharing options...
technologic
4 answers to this question
