Black out - Anthony Posted March 29, 2013 Share Posted March 29, 2013 Hi, are what I'm wrong or buttery wax is a bit like a wax with Teflon and can be applied directly to the wheels and body while americana, it is better to respect the 3 steps: sealant, glaze and wax? Link to comment Share on other sites More sharing options...
0 Chewy Posted March 29, 2013 Share Posted March 29, 2013 (edited) Incorrect! You can treat them the same way, keeping in mind Americana likes to go on a couple of panels and be removed, whereas you can apply buttery to the whole car and then go back and remove it. Buttery doesn't mind being applied in direct sun (cooler temps), whereas Americana will harden like concrete in a matter of minutes or seconds under the sun. lol Buttery is an awesome "gotta do it quick" product that has some paint imperfection hiding abilities. Sealants just rock for durability! The glaze adds depth and also hides paint imperfections. Personally, on a DD I use AQS or MSS for durability. Chris Edited March 29, 2013 by Chewy Link to comment Share on other sites More sharing options...
0 mc2hill Posted March 29, 2013 Share Posted March 29, 2013 No Teflon, just some Carnauba. It goes on very smoothly, but does not protect as long Americana, QS or MSS. Link to comment Share on other sites More sharing options...
0 Black out - Anthony Posted March 29, 2013 Author Share Posted March 29, 2013 it is a synthetic wax? it has better resists heat? Link to comment Share on other sites More sharing options...
0 Black out - Anthony Posted March 29, 2013 Author Share Posted March 29, 2013 I heard that the teflon does not protect anything? just repel water and that's it?! Link to comment Share on other sites More sharing options...
0 Black out - Anthony Posted March 29, 2013 Author Share Posted March 29, 2013 what do you think? I like to learn. This is because there are special waxes rim and I wonder what Adam's product can do? Link to comment Share on other sites More sharing options...
0 Chewy Posted March 29, 2013 Share Posted March 29, 2013 Teflon is added to it to make you think it's something worth having. It's a marketing ploy honestly. For Teflon to do anything it'd have to be fused to the paint. Seeing that it takes hundreds of degrees to do so, I can't see it helping in the paint protection field. Honestly, if it did, more people would have it. I believe there are some synthetic properties to BW, but it does contain carnuba. If you want synthetics and to have heat protection, go with MSS or AQS. Carnuba's do not handle the heat like the sealants do, which is one of the reasons I use a sealant on my DD's. Chris Link to comment Share on other sites More sharing options...
0 Black out - Anthony Posted March 29, 2013 Author Share Posted March 29, 2013 ok, so for my rims I apply the sealant and that's all. the buttery wax will resist not only to heat the rims? Link to comment Share on other sites More sharing options...
0 Chewy Posted March 29, 2013 Share Posted March 29, 2013 ok, so for my rims I apply the sealant and that's all. the buttery wax will resist not only to heat the rims? You can top the sealant on the rims with BW if you like. It will give them a bit more depth perhaps. It's not necessary however. Chris Link to comment Share on other sites More sharing options...
0 Doug123 Posted March 29, 2013 Share Posted March 29, 2013 My two cents is that if you have Quick Sealant, that would be the best protection solution for the wheels. On a clean wheel, you can mist it on, wipe it down, then wipe it off, and it holds up well. Link to comment Share on other sites More sharing options...
0 Black out - Anthony Posted March 29, 2013 Author Share Posted March 29, 2013 ok thank you Link to comment Share on other sites More sharing options...
0 livingwater Posted March 30, 2013 Share Posted March 30, 2013 I use Adam's VRT on the tires and Brilliant spray glaze on the wheels. I leave the Buttery wax for the sexy curves on the body Link to comment Share on other sites More sharing options...
Black out - Anthony
11 answers to this question
