IAcamoprincess01 Posted July 3, 2014 Share Posted July 3, 2014 Do I clay my windows and rims as well as the body and if so is there a particular order I should do this in or does it matter? Link to comment Share on other sites More sharing options...
0 LFairbanks Posted July 3, 2014 Share Posted July 3, 2014 Yes, You can clay your windows and wheels. Just remember once you use it on the wheels you don't use it on your paint again. Maybe stash it away in a separate container. I save all my old clay for this purpose as well as the real nasty areas. Link to comment Share on other sites More sharing options...
0 Kingsford Posted July 3, 2014 Share Posted July 3, 2014 I clay my wheels after every wash, probably over kill but it always makes them shine better and I just hit them with some Spray Seal. I do my windows less often because I apply Glass Sealant and I would believe that would remove it and it's not cheap. Link to comment Share on other sites More sharing options...
0 Tim Posted July 3, 2014 Share Posted July 3, 2014 The proper order is: Paint, glass, wheels, garbage. Unless you drop it, then straight to garbage. You can probably get multiple uses on paint (provided you don't use it elsewhere), etc. Out of one piece. Link to comment Share on other sites More sharing options...
0 Kingsford Posted July 3, 2014 Share Posted July 3, 2014 The proper order is: Paint, glass, wheels, garbage. Unless you drop it, then straight to garbage. You can probably get multiple uses on paint (provided you don't use it elsewhere), etc. Out of one piece. I use mine until it starts to discolor, on the paint. Then it goes into a jar labeled glass, then a jar labeled wheels where I get a ton of uses out of it until it looks really discolored then the garbage. Don't drop it... That gets expensive lol Link to comment Share on other sites More sharing options...
0 IAcamoprincess01 Posted July 3, 2014 Author Share Posted July 3, 2014 Thanks for all the help everybody:) Link to comment Share on other sites More sharing options...
IAcamoprincess01
5 answers to this question
