The Cyclo is a great tool to apply LPS using the 4" Gray Sealant & Waxing pad. Did you know that it's a great tool for removing LPS too? It's best if you replace your pads with clean ones so they won't bleed through your Double Soft MF towel. Lay your Double soft down diagonal hold a corner with each hand turn Cyclo on speed 2 or 3 and go to town. That's it you will be done in no time flat!
Chris@Adams
4 answers to this question
