Flip Posted August 28, 2016 Share Posted August 28, 2016 Is there a trick to this? It only will work after I've run the machine for several seconds. Sometimes it doesn't work then either. Link to comment Share on other sites More sharing options...
0 Flip Posted August 28, 2016 Author Share Posted August 28, 2016 I think I found the trick on mine. Link to comment Share on other sites More sharing options...
0 Dylan@RUPES Posted August 28, 2016 Share Posted August 28, 2016 The trigger lock? No real trick - just pull the trigger all the way, press the lock button, release the trigger and it's locked on. Pull the trigger again and release to stop. Link to comment Share on other sites More sharing options...
0 Flip Posted August 28, 2016 Author Share Posted August 28, 2016 I had to find the right pressure on where to hold the trigger. Mine will not lock if I pull the trigger all the way. It will lock when I just lightly pull the trigger. Works nice after I found the sweet spot. Link to comment Share on other sites More sharing options...
Flip
3 answers to this question
