Kickerz71 Posted June 11, 2017 Share Posted June 11, 2017 I received my Swirl Killer and now have my PC that I want to convert to use 4 inch pads. What size is recommend as a backing plate? I see I can get either a 4 inch from Adams or 3.5 from Lake Country. I plan on using Adams pads thanks Link to comment Share on other sites More sharing options...
0 TheWolf Posted June 11, 2017 Share Posted June 11, 2017 I received my Swirl Killer and now have my PC that I want to convert to use 4 inch pads. What size is recommend as a backing plate? I see I can get either a 4 inch from Adams or 3.5 from Lake Country. I plan on using Adams pads thanks Get the Adam's 4” Machine Polisher Backing Plate since you will be using Adam's pads. The face of this backing plate actually measures a little less than 3 inches, and the Velcro on the 4" pad measures about 3.25 inches, which allows you to center the pad and not have any edge of the backing plate sticking out, to help prevent damage should you accidently bump the side of the pad into the car. Kickerz71 and Nickfire20 2 Link to comment Share on other sites More sharing options...
Kickerz71
thanks
1 answer to this question
