I read that Gel Coat is a harder surface than paints & clear coat, so much tougher to correct. OK - I'll have to use a more aggressive compound and just work harder than most of the surfaces on cars.
Also from what I read once oxides & scratches have been cut/corrected/polished the Gel Coat will be nice and smooth but is a more porous surface than painted surfaces. If I were to proceed with Adam's Graphene coating on this porous material what should I expect? Will it 'sink' into the pores? Will it level properly? How about on vertical surfaces?
BGP
1 answer to this question
