Coach66 Posted May 31, 2009 Share Posted May 31, 2009 I think I have asked this question before, but cannot find the post. If I wanted to go "all out" with a detail job on an older paint car, would this be the order? Wash-Clay-Swirl and Haze Remover-Fine Machine Polish-Revive-SprayGlaze-Wax-Detail Spray. Or, does the Revive come earlier to remove older wax and glazes? Or, is there a step here that is counter-productive, like Spray Glaze, or Detail Spray? Is there a step missing? Link to comment Share on other sites More sharing options...
0 GerryC Posted May 31, 2009 Share Posted May 31, 2009 (edited) I'm assuming you're using a porter cable because of the machine polish step, in that case you might not need to use Revive after that, but some people do, it certainly won't be counter-productive The only thing is that the spray glaze should come after the wax. Also you don't need to use detail spray immediately after removing the wax (you can if you want to, others do, but I don't), just as a maintenance product once a day to remove light dust and smudges Edited May 31, 2009 by GerryC Link to comment Share on other sites More sharing options...
0 Coach66 Posted May 31, 2009 Author Share Posted May 31, 2009 Thanks Gerry. I havent used Detail spray right after before either, but I have read that many do. Thanks for the heads up on the spray glaze. The reason I asked about the Revive is everyone talks about how much depth it gives to color, so I bought some to try. I just want to make sure I put it on in the "proper" order to get the best reults. Anyone else? Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted May 31, 2009 Share Posted May 31, 2009 I'm assuming you're using a porter cable because of the machine polish step, in that case you might not need to use Revive after that, but some people do, it certainly won't be counter-productive The only thing is that the spray glaze should come after the wax. Also you don't need to use detail spray immediately after removing the wax (you can if you want to, others do, but I don't), just as a maintenance product once a day to remove light dust and smudges :iagree: Link to comment Share on other sites More sharing options...
0 estecoca Posted May 31, 2009 Share Posted May 31, 2009 I believe that the spray glaze is best as a final step, regardless of the wax being used. Link to comment Share on other sites More sharing options...
0 Tmag Posted May 31, 2009 Share Posted May 31, 2009 Maybe this will help FREE DOWNLOAD: Detailing Reference Cards! http://www.adamsforums.com/forums/showpost.php?p=8393&postcount=1 Link to comment Share on other sites More sharing options...
0 itsjer Posted May 31, 2009 Share Posted May 31, 2009 Maybe this will help FREE DOWNLOAD: Detailing Reference Cards! http://www.adamsforums.com/forums/showpost.php?p=8393&postcount=1 The reference cards are good for hand waxing. Use Bill's directions for machine use. http://www.adamsforums.com/forums/showthread.php?t=1161 Link to comment Share on other sites More sharing options...
0 Coach66 Posted June 1, 2009 Author Share Posted June 1, 2009 Ive got the card and have watched the videos. But, no one has used all of the waxing/polishing products at once. That in fact may answer my question, but then you get into "What product do I leave out?" So, I'll just use them all. Thanks for all of the replies. Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted June 1, 2009 Share Posted June 1, 2009 (edited) Ive got the card and have watched the videos. But, no one has used all of the waxing/polishing products at once. That in fact may answer my question, but then you get into "What product do I leave out?" So, I'll just use them all. Thanks for all of the replies. You know, it really depends a lot on the color of the car. A white car can get by with a lot less product use than a black car, provided that you are not going for that showroom, show circuit type look. A white daily driver can easily get by without the Revive or BSG steps. Even a dark colored car doesn't necessarily need all those steps as there comes a point where you are not going to see any difference once you get so far. Different finishes and different colors require different approaches. There is no "set in stone" process that you must follow that is best for every finish out there, thus you must experiment and figure out what works best for your given situation. Edited June 4, 2009 by Junkman2008 Link to comment Share on other sites More sharing options...
0 jjwvette Posted June 3, 2009 Share Posted June 3, 2009 Great answer AJ Link to comment Share on other sites More sharing options...
0 Team Adam's Posted June 3, 2009 Share Posted June 3, 2009 Not at all necessary to do ALL of those steps... I'd go with the following: Wash Clay SHR FMP Revive (not required, but it will deep clean/feed the paint) Wax (Americana, MSW, or BW) DONE. If you want to work BSG in it should be your last step product, but honestly I'd recommend it as a product to bring some life back to the finish between waxing. Link to comment Share on other sites More sharing options...
Coach66
10 answers to this question
