jeast Posted June 9, 2009 Share Posted June 9, 2009 The RP (Revive Polish) has cutting power right ? What does RP, SHR, and FMP do to a clear coat ? My car's paint seems to be real soft, does any one know anything about 05 GTO paint ? Link to comment Share on other sites More sharing options...
0 11chevz71 Posted June 9, 2009 Share Posted June 9, 2009 The RP (Revive Polish) has cutting power right ? What does RP, SHR, and FMP do to a clear coat ? My car's paint seems to be real soft, does any one know anything about 05 GTO paint ? The way it should go is the shr is the most adbrasive then you go to the fmp which is very less adbrasvie then you apply the revive. I think the revive is more a cleaner i have heard of it cutting some oxidation down on one post. And i think the gto paint should not be that hard to correct. Link to comment Share on other sites More sharing options...
0 jeast Posted June 9, 2009 Author Share Posted June 9, 2009 The way it should go is the shr is the most adbrasive then you go to the fmp which is very less adbrasvie then you apply the revive. I think the revive is more a cleaner i have heard of it cutting some oxidation down on one post. And i think the gto paint should not be that hard to correct. Im talking more about it hurting my clear coat. Does it take some of the clear coat off ? Link to comment Share on other sites More sharing options...
0 11chevz71 Posted June 9, 2009 Share Posted June 9, 2009 Im talking more about it hurting my clear coat. Does it take some of the clear coat off ? IF it would take clear coat off adams would not make it. You do not need to worry. All the revive polish is is a shine enhancer. Link to comment Share on other sites More sharing options...
0 Baron_Von_Awesome Posted June 9, 2009 Share Posted June 9, 2009 The RP (Revive Polish) has cutting power right ? What does RP, SHR, and FMP do to a clear coat ? My car's paint seems to be real soft, does any one know anything about 05 GTO paint ? It takes a combination of things to rip through a clear coat - a Porter Cable coupled with any Adam's polish is not that combination. You have nothing to worry about and it's completely safe to use. Link to comment Share on other sites More sharing options...
0 jeast Posted June 9, 2009 Author Share Posted June 9, 2009 Ok good. Thanks your help guys. Link to comment Share on other sites More sharing options...
0 Loud Pedal Posted June 9, 2009 Share Posted June 9, 2009 But remember you are removing a very small amount of clear when correcting paint, so don't go wild on edges and such as there might be a chance there is less clear on those areas. Link to comment Share on other sites More sharing options...
0 jjwvette Posted June 9, 2009 Share Posted June 9, 2009 Jared are you using a PC? or are you doing this by hand? Link to comment Share on other sites More sharing options...
0 jeast Posted June 9, 2009 Author Share Posted June 9, 2009 Jared are you using a PC? or are you doing this by hand? Just hand right now but I want to get a pc soon. Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted June 10, 2009 Share Posted June 10, 2009 Just hand right now but I want to get a pc soon. If you are doing this by hand, then you'll rip you some new finger tips before you'll even come close to going through the clear. Fixing scratches using the PC is called paint correction. Fixing scratches by hand is called... Exercise. Link to comment Share on other sites More sharing options...
0 jeast Posted June 10, 2009 Author Share Posted June 10, 2009 I want a PC but I just dont want to use anything that will take off some of the clear coat. Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted June 10, 2009 Share Posted June 10, 2009 I want a PC but I just dont want to use anything that will take off some of the clear coat. In order to repair scratches in the clear coat, you must remove some of the clear coat. Now keep in mind that the amount of clear coat that you are removing is extremely minimal when using Adam's products, however, some products by manufacturers like Meguiar's are capable of removing clear coat and some paint too. Adam's doesn't sell anything that brutal. Link to comment Share on other sites More sharing options...
0 bigred vette Posted June 10, 2009 Share Posted June 10, 2009 Also to add to A.J's post, the PC does not spin like a rotary but occilates. The pc does not build up enough heat by doing this to remove to much of the clear. Link to comment Share on other sites More sharing options...
0 Baron_Von_Awesome Posted June 10, 2009 Share Posted June 10, 2009 Adam's doesn't sell anything that brutal. Indeed. Safety first!! Link to comment Share on other sites More sharing options...
0 Superdutytd Posted June 11, 2009 Share Posted June 11, 2009 Indeed. Safety first!! I agree so much I even have T shirts that say this on the back! Link to comment Share on other sites More sharing options...
jeast
14 answers to this question
