How do I Fix This?
Devin04
12 answers to this question
It's not so much glass as it is a plastic. That clear polish might work I forgot about that. Also I have this 3M headlight restoring polish somewhere that I thought might work. I don't really feel like taking it apart to get a buffer on it. Since those house all the gauges and odometer they are usually pretty hard to get into I might end up causing more damage. I might try masking it off and using some SHR, FMP, or that stuff from 3M by hand. Thanks for the ideas.
Those marks are really hard to get out because that plastic is so soft - I normally don't recommend trying anything on it because oftentimes there's no going back - if you use something too aggressive, you're stuck with the scratches.
I don't need it perfect, I just want to smooth out some of the swirls. Would even FMP by hand be too much? I don't think it could get much worse.
