cpetes Posted June 21, 2009 Share Posted June 21, 2009 Just recieved my new PC and no starty??? Link to comment Share on other sites More sharing options...
0 livingwater Posted June 21, 2009 Share Posted June 21, 2009 If your sure the wall recepticle has voltage try this: Try turning the shaft and then try turning on the PC. If you have an Ohm meter try the following: 1. Unplug the PC from the power source 2. Put meter on ohm's and touch the meter leads to the two flat blades located on the plug for the PC 3. With the ohm meter leads on the plug turn the switch on. Do you get a resistance reading on the PC? Link to comment Share on other sites More sharing options...
0 Guest AeroCleanse Posted June 21, 2009 Share Posted June 21, 2009 Just recieved my new PC and no starty??? Call where you got it from and tell them. Link to comment Share on other sites More sharing options...
0 Baron_Von_Awesome Posted June 21, 2009 Share Posted June 21, 2009 Plugged into GFI outlet that needs to be reset...? Might as well start with the easy stuff first... Link to comment Share on other sites More sharing options...
0 11chevz71 Posted June 21, 2009 Share Posted June 21, 2009 First check is the breaker is hit. THen if the breaker is not hit then if you have a thinging that light up if there is juice when put it in the recepticle check if you a are getting juice. IF not does your ext-cord work. many possibilties most likely faulty machine. Link to comment Share on other sites More sharing options...
0 jjwvette Posted June 22, 2009 Share Posted June 22, 2009 Link to comment Share on other sites More sharing options...
cpetes
5 answers to this question
