Anyone know the best way in doing this, I've done it before by wet sanding. Just wondering if any Adam's product can help here. The process that I've used before on my older car was this.
Wet sand the headlight with 1,500 grit
Sanding only with a side to side movement.
Sprayed water as needed on the area while sanding.
Stoped until the water run off is white or clear.
Rinsed with water and wipe down the headlight lens.
Wet sand the headlight with 3,000 grit
Sanded in any motion. (Circular is easiest)
Stoped until all side to side scratches are removed.
Polish the lens to remove the 3,000 grit scratches
Spreading a polish evenly over the entire lens.
Using a MF towel to polish and buff out the lens with circular motions
Wash the headlight.
Using Soap and water.
Washing twiceto remove all traces of silicates.
Dry the headlight.
Completely dry the headlight lens.
Allow 10 minutes to let any moisture on the lens to evaporate.
Apply Sealant.
Using a MF towel and rub in a circular motion.
Making sure to cover the entire headlight lens area.
But like I said I'm wondering if I can use the focus pads, and some adam's product.
Oupavoc
Wash the headlight.
Dry the headlight.
Apply Sealant.
19 answers to this question
