Goatman06 Posted June 1, 2010 Share Posted June 1, 2010 Like stated above to apply revive with the PC wich pad should be used? thanks. Link to comment Share on other sites More sharing options...
Chewy Posted June 1, 2010 Share Posted June 1, 2010 White as it's a polish so it will "polish" as it works. You can also use gray if you like but it won't "polish" as much... lol Chris Link to comment Share on other sites More sharing options...
Zeus_SVT Posted June 1, 2010 Share Posted June 1, 2010 I use the white one too because I am totally against applying by hand now that I have learned how to use the PC. It's most likely gonna turn your pad permanently blue, as it did mine. But just wash it real good to get the polish out once you're done and you'll be ok. Once I used revive on it one time I just decided to devote that one pad to Revive and still have a separate one for the FMP. Link to comment Share on other sites More sharing options...
Goatman06 Posted June 1, 2010 Author Share Posted June 1, 2010 thanks for the help guys ill use the white one. Link to comment Share on other sites More sharing options...
Chris@Adams Posted June 1, 2010 Share Posted June 1, 2010 Have fun Bob! Link to comment Share on other sites More sharing options...
Goatman06 Posted June 1, 2010 Author Share Posted June 1, 2010 Will do sir.. Link to comment Share on other sites More sharing options...
bankO_MaN Posted June 1, 2010 Share Posted June 1, 2010 Why use revive over fmp if using a PC? Just curious as I've never used revive. Link to comment Share on other sites More sharing options...
Chris@Adams Posted June 1, 2010 Share Posted June 1, 2010 Why use revive over fmp if using a PC? Just curious as I've never used revive. I always use one or the other, some use both on dark colored paint.They say it gives a bit more depth. Link to comment Share on other sites More sharing options...
Goatman06 Posted June 1, 2010 Author Share Posted June 1, 2010 I use the white one too because I am totally against applying by hand now that I have learned how to use the PC. It's most likely gonna turn your pad permanently blue, as it did mine. But just wash it real good to get the polish out once you're done and you'll be ok. Once I used revive on it one time I just decided to devote that one pad to Revive and still have a separate one for the FMP. Zeus summed it up no more hand application for me either, I just want to receive the best results possible. Link to comment Share on other sites More sharing options...
bankO_MaN Posted June 1, 2010 Share Posted June 1, 2010 I always use one or the other, some use both on dark colored paint.They say it gives a bit more depth. Well...my car is Black after all. More depth is alawys a good thing! I have a problem... Link to comment Share on other sites More sharing options...
Goatman06
9 answers to this question
