srthemi Posted June 22, 2010 Share Posted June 22, 2010 Does anyone else have problems with there pc when using it on the side panels of your vehicle? Mine seems to lose it's power and I can't apply the same amount of pressure as I can on the tops of my car or truck. Aso what size counter balancer weight should you use on adams 7 1/2" pads? Link to comment Share on other sites More sharing options...
JerseyGator Posted June 22, 2010 Share Posted June 22, 2010 Never any issues... Watch part 2 of this video series. Tons of info on the pc. http://www.adamsforums.com/forums/showthread.php?t=2386 Link to comment Share on other sites More sharing options...
Chris@Adams Posted June 22, 2010 Share Posted June 22, 2010 Never any issues... Watch part 2 of this video series. Tons of info on the pc. http://www.adamsforums.com/forums/showthread.php?t=2386 Right on Peter! Link to comment Share on other sites More sharing options...
Team Adam's Posted June 22, 2010 Share Posted June 22, 2010 Does anyone else have problems with there pc when using it on the side panels of your vehicle? Mine seems to lose it's power and I can't apply the same amount of pressure as I can on the tops of my car or truck. Aso what size counter balancer weight should you use on adams 7 1/2" pads? Very unusual. When you say it seems to 'lose its power' what specifically is indicating that... do the OPM's drop off significantly? Also have you verified you're using the correct gauge of extension cord? We recommend using the 5" weight that ships with the machine... the 6" weight seems to make the machine more difficult to manage at different speeds. Link to comment Share on other sites More sharing options...
srthemi Posted June 22, 2010 Author Share Posted June 22, 2010 I just got done watching that video Again for the 4th time. And it still dosen't tell me why my pc seems to lose power when I go to do a side panel. Link to comment Share on other sites More sharing options...
srthemi Posted June 22, 2010 Author Share Posted June 22, 2010 When I'm doing a side panel I can't put the same pressure on the pc as I can when on the top panel. Unless I let up on the pressure you can see it stop the circlure motion. Maybe I need to get a bigger gauge extion cord. And also I'm thinking aboiut getting adams new 7 1//2" pads, do I need to have a larger counter weight? Link to comment Share on other sites More sharing options...
Team Adam's Posted June 22, 2010 Share Posted June 22, 2010 When I'm doing a side panel I can't put the same pressure on the pc as I can when on the top panel. Unless I let up on the pressure you can see it stop the circlure motion. Maybe I need to get a bigger gauge extion cord. And also I'm thinking aboiut getting adams new 7 1//2" pads, do I need to have a larger counter weight? Can't really tell you if you need the "larger" weight if we don't know what weight you have now, but you need the 5" weight by our recommendations. What speed are you operating the machine at? What kind of pads are you running now if you're not using ours? Link to comment Share on other sites More sharing options...
srthemi Posted June 22, 2010 Author Share Posted June 22, 2010 I have a 5 weight and I want to start using adams new pads but I'm not sure if I need a bigger counter weight with the new pads. I usualy run at speed 5 using the FMP and speed of 3 using the Super wax. Link to comment Share on other sites More sharing options...
