AVA182 Posted July 12, 2010 Share Posted July 12, 2010 I just received my Carpet and upholster cleaner and when i went to put in the sprayer it was entirely too long...so i figured you would just have to force it in and then screw it on. So I tried that and I could not get the sprayer closed on. So I cant get the bottle to close correctly so I'm just wandering what to do. Thanks, kgregg97 Link to comment Share on other sites More sharing options...
03silvss Posted July 12, 2010 Share Posted July 12, 2010 just snip the end of the plastic with scissors problem solved Link to comment Share on other sites More sharing options...
Nordgrey Posted July 12, 2010 Share Posted July 12, 2010 There seems to be a new bottle. Same volume, but a bit more squat. I just snipped off a half inch or so from the take up tube on the sprayer. Had to do that with all my gallon pump tubes as well. Link to comment Share on other sites More sharing options...
Mustang08 Posted July 12, 2010 Share Posted July 12, 2010 yeah had that problem today when i went to put the sprayer in just cut off alittle bit of the tube to make it fit Link to comment Share on other sites More sharing options...
crime2 Posted July 12, 2010 Share Posted July 12, 2010 Had to do that with all my gallon pump tubes as well. Just had to do the same on Friday also. Link to comment Share on other sites More sharing options...
AVA182 Posted July 12, 2010 Author Share Posted July 12, 2010 That is what I ended up doing but i feel now that it will be difficult to use the liquid in the bottom of the sprayer...we'll see though. Link to comment Share on other sites More sharing options...
03silvss Posted July 12, 2010 Share Posted July 12, 2010 well if your trying to squeeze out that little bit of fluid shes times to open a gallon jug and fill up the bottle Link to comment Share on other sites More sharing options...
AVA182 Posted July 12, 2010 Author Share Posted July 12, 2010 well if your trying to squeeze out that little bit of fluid shes times to open a gallon jug and fill up the bottle I need to get one first haha Link to comment Share on other sites More sharing options...
Laguna Posted July 12, 2010 Share Posted July 12, 2010 I just force it on, because as stated, when the bottle gets low and you don't have a gallon for refill, you can get every last squirt out! Link to comment Share on other sites More sharing options...
svrds10 Posted July 12, 2010 Share Posted July 12, 2010 I had to snip a little of the bottom. Dont snip too much though. You want it to have a little bed to it or almost tough the bottom so that it can use up all of the bottle Link to comment Share on other sites More sharing options...
Chris@Adams Posted July 12, 2010 Share Posted July 12, 2010 They are all too long but it will force in. That way it will suck all out of the bottom of bottle. Link to comment Share on other sites More sharing options...
Foxxer Posted July 12, 2010 Share Posted July 12, 2010 Use force, problem solved, worked for me atleast. Link to comment Share on other sites More sharing options...
Chewy Posted July 12, 2010 Share Posted July 12, 2010 I've done both... Forced and let it curl at the bottom or cut it off. I have gallons to go along side my sprayers so I'm never looking to get ALL of the product out. Both methods work fine. Chris Link to comment Share on other sites More sharing options...
rachelanne16 Posted July 29, 2010 Share Posted July 29, 2010 Maybe read the bottle or label of that carpet cleaner first before you use. And I think there are manuals about that cleaner. Maybe you have read it first. Link to comment Share on other sites More sharing options...
