the Camaro show Posted December 31, 2017 Share Posted December 31, 2017 Hi guys I got a standard foam gun for Christmas and I can’t get it to connect from the back of the gun to the quick release connect part no matter how hard I push? Anyone else with this problem or any way to fix it Link to comment Share on other sites More sharing options...
0 blcksilv08 Posted December 31, 2017 Share Posted December 31, 2017 20 hours ago, the Camaro show said: Hi guys I got a standard foam gun for Christmas and I can’t get it to connect from the back of the gun to the quick release connect part no matter how hard I push? Anyone else with this problem or any way to fix it I've seen people have trouble before and a small amount of lubricant on the o ring may help. If that doesn't remedy it, reach out to Adams and they will definitely take care of you! Link to comment Share on other sites More sharing options...
0 Firebuff17 Posted January 1, 2018 Share Posted January 1, 2018 I have not seen the standard foam gun, but I had similar problem on the premium. The remedy was to just slightly loosen the quick connect on the end where the canister connects to the nozzle. Still it’s a tight connection with now leaks after slightly loosening. Best of luck Link to comment Share on other sites More sharing options...
0 Altrdprcptn Posted February 16, 2018 Share Posted February 16, 2018 I've been experiencing this too and just living with it. Lately, it has become more of a nuisance to me and I have been searching the forums for others with this issue. I need to have the quick connect very loose before it connects properly. Once it is connected I will retighten the hose to eliminate leaking. Honestly, it is bad enough where I dont even consider it a quick connect anymore since I am basically having to loosen and tighten the connection manually each time. Link to comment Share on other sites More sharing options...
0 falcaineer Posted February 16, 2018 Share Posted February 16, 2018 18 minutes ago, Altrdprcptn said: I've been experiencing this too and just living with it. Lately, it has become more of a nuisance to me and I have been searching the forums for others with this issue. I need to have the quick connect very loose before it connects properly. Once it is connected I will retighten the hose to eliminate leaking. Honestly, it is bad enough where I dont even consider it a quick connect anymore since I am basically having to loosen and tighten the connection manually each time. Sorry this has become such a problem. As Eric said above, highly recommend you call Adam's and explain what's going on. They'll take care of you if at all possible. Link to comment Share on other sites More sharing options...
0 mathews31 Posted February 17, 2018 Share Posted February 17, 2018 I had a problem with my nozzle not releasing back to the original position and when I contacted my Adam's dealer he got it changed out easily Link to comment Share on other sites More sharing options...
the Camaro show
5 answers to this question
