Wk2Altitude15 Posted April 11, 2019 Share Posted April 11, 2019 Knowing that a true ceramic coating has to be removed by machine , how about the Ceramic Boost? Will a strip wash be strong enough to remove it seeing as its such a lesser amount of Sio2? Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted April 11, 2019 Share Posted April 11, 2019 It’s really just a wax on steroids so I would think a good strip wax would be sufficient if the car has to be corrected then use a machine but first clay where necessary Link to comment Share on other sites More sharing options...
0 Wk2Altitude15 Posted April 12, 2019 Author Share Posted April 12, 2019 On 4/11/2019 at 9:51 AM, buffalobob920 said: It’s really just a wax on steroids so I would think a good strip wax would be sufficient if the car has to be corrected then use a machine but first clay where necessary thanks, this is true however it does have the sio2 in it and im figuring about 10% or so. However it works incredible as a standalone sealant. but warmer weather is here and i wanted to strip everything and clay so i figured that would remove it all anyway. Link to comment Share on other sites More sharing options...
0 falcaineer Posted April 12, 2019 Share Posted April 12, 2019 1 hour ago, Wk2Altitude15 said: thanks, this is true however it does have the sio2 in it and im figuring about 10% or so. However it works incredible as a standalone sealant. but warmer weather is here and i wanted to strip everything and clay so i figured that would remove it all anyway. Strip wash, clay and polish will remove it. Adam's advertises the Boost at 15% SiO2; posted a link below from @Parad0x that outlines the others (not: Ceramic Waterless is 7%, it's a mistake on the chart). Link to comment Share on other sites More sharing options...
Wk2Altitude15
3 answers to this question
