I am starting this thread because of the new Flex that Adam is offering. I like most probably have many questions on the Flex.
So post away your questions, I feel confident that the more knowledganble among us will help the rest of us out.
My questions.
With the PC you use 9 to 14 lbs of pressure, how much do you use with the flex?
On inside corners/curves of body panels is using the edge ok on the flex?
How fast do you move the flex?
The product can be worked longer, so how long do you work the product. The PC you work it till it looks like vaseline almost. How do you tell with the flex?
Since it has more cut how many passes should you normally do in each stage with the flex?
Dr Jkel
My questions.
Thanks,
John
19 answers to this question
