musclejunkie Posted May 4, 2011 Share Posted May 4, 2011 Question? Do I need SHR to remove this stuff or will FMP get it off? Just what causes this? Not enough or too much lube? The clay? Thanks. Link to comment Share on other sites More sharing options...
MAYBEN Posted May 4, 2011 Share Posted May 4, 2011 Like mentioned above, Use more lube and once you break out the poilisher it will all disappear I agree.. but I never knew it was called poilishing in Canucksville.. learning new things every day eh Link to comment Share on other sites More sharing options...
Chewy Posted May 4, 2011 Share Posted May 4, 2011 I'm half french canadian as well... Canuck stands... I've NEVER heard it said in anger, like I had heard the other said. Link to comment Share on other sites More sharing options...
MAYBEN Posted May 4, 2011 Share Posted May 4, 2011 I'll let you slide this time.. Link to comment Share on other sites More sharing options...
musclejunkie Posted May 4, 2011 Author Share Posted May 4, 2011 Just funnin ya's of course! Link to comment Share on other sites More sharing options...
musclejunkie Posted May 4, 2011 Author Share Posted May 4, 2011 Ahh hah!!!! Gotcha! I'll take back my 1 point violation now. Link to comment Share on other sites More sharing options...
MAYBEN Posted May 4, 2011 Share Posted May 4, 2011 ahh so I bet all the players are offended besides.. I have some Canadian French in my bloodlines.. lol Link to comment Share on other sites More sharing options...
musclejunkie Posted May 4, 2011 Author Share Posted May 4, 2011 :help:So where is "canucksville"? Link to comment Share on other sites More sharing options...
Bill-V8V Posted May 4, 2011 Share Posted May 4, 2011 I don't know, Dictionary.com might disagree Ca·nuck (k-nk) KEY NOUN: Often Offensive Slang <dl><dd> A Canadian, especially a French Canadian.</dd></dl><hr size="0" width="100%" align="left">ETYMOLOGY: Probably alteration of Canadian Link to comment Share on other sites More sharing options...
Chewy Posted May 4, 2011 Share Posted May 4, 2011 theres no ethnic slurs in there.. Nope! Not at all... We only take issue with ACTUAL racial slurs. Link to comment Share on other sites More sharing options...
MAYBEN Posted May 4, 2011 Share Posted May 4, 2011 theres no ethnic slurs in there.. Link to comment Share on other sites More sharing options...
musclejunkie Posted May 4, 2011 Author Share Posted May 4, 2011 I agree.. but I never knew it was called poilishing in Canucksville.. learning new things every day eh Careful with the ethnic slurrs.....the slur police are watching! Brought to you by a kinder, gentler junkie. Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted May 4, 2011 Share Posted May 4, 2011 Like mentioned above, Use more lube and once you break out the poilisher it will all disappear Link to comment Share on other sites More sharing options...
Chris@Adams Posted May 4, 2011 Share Posted May 4, 2011 Always start with the less aggressive product first (FMP), Then if that doesn't work step up to SHR or SSR! Like mentioned before use more DS when claying. Link to comment Share on other sites More sharing options...
Chewy Posted May 4, 2011 Share Posted May 4, 2011 I haven't used the Adam's clay yet, just getting ready to do the first detail on my new Mustang. The other clay I used on my other car went well with only some marring on one fender area. It was a pain to get off though. I don't apply much pressure either and I let the clay do the work applying liberal DS as I go. Does the clay break down after a while? Is this what causes the marring? I think the marring is actually clay residue is it not? No, the marring is actually very fine scratches left behind. Using more DS helps, but doesn't always eliminate them. Chris Link to comment Share on other sites More sharing options...
musclejunkie Posted May 4, 2011 Author Share Posted May 4, 2011 I haven't used the Adam's clay yet, just getting ready to do the first detail on my new Mustang. The other clay I used on my other car went well with only some marring on one fender area. It was a pain to get off though. I don't apply much pressure either and I let the clay do the work applying liberal DS as I go. Does the clay break down after a while? Is this what causes the marring? I think the marring is actually clay residue is it not? Link to comment Share on other sites More sharing options...
Chewy Posted May 4, 2011 Share Posted May 4, 2011 I can't wait until this U.S. pantent is up on clay... Oh the cool things we'll see then... Chris Link to comment Share on other sites More sharing options...
camaro2ssblack Posted May 4, 2011 Share Posted May 4, 2011 the FMP will remove the marring and light swirls..it may take a few passes though. just do a pass on a test area, wipe and check the results, and repeat if necessary. if after 2-3 passes you see no significant improvement, step up to SHR.. Link to comment Share on other sites More sharing options...
Bill-V8V Posted May 4, 2011 Share Posted May 4, 2011 How much marring are you getting ? You might want to go a little easier on the clay or use a little more lube. Link to comment Share on other sites More sharing options...
musclejunkie Posted May 4, 2011 Author Share Posted May 4, 2011 Marring is to be expected when claying, you should never clay unless you plan to polish. I plan on doing a full detail after the clay. When I've clayed in the past, doing a detail by hand, it was a pain to remove some of the marring. This time I plan on doing a PC detail, but would not like to have to pull out the SHR unless I have to. Link to comment Share on other sites More sharing options...
Bill-V8V Posted May 4, 2011 Share Posted May 4, 2011 Marring is to be expected when claying, you should never clay unless you plan to polish. Link to comment Share on other sites More sharing options...
musclejunkie
20 answers to this question
