Z06Addict Posted June 2, 2011 Share Posted June 2, 2011 Any sugestiones on a foam cannon to buy?? Link to comment Share on other sites More sharing options...
Billyt Posted June 2, 2011 Share Posted June 2, 2011 Any sugestiones on a foam cannon to buy?? http://www.adamsforums.com/forums/showthread.php?t=11721 Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted June 2, 2011 Share Posted June 2, 2011 That Cannon doesn't have any attachments. It looks like just the wand and bottle. You can try the "nerds" I know they have them. I bought mine from a place in Canada called eshine. Link to comment Share on other sites More sharing options...
3PedalMINI Posted June 3, 2011 Share Posted June 3, 2011 actually, that is a standard pipe thread and if you have a "lance" (26" pipe you put your nozzles on) it fits. The pressure washer place has all the adapters and fittings you could imagine too so i wouldn't worry about the "attachments". besides, its 43 bucks and is the cheapest foam gun i found and it looks to be identical to the ones the detailer's sites sell Link to comment Share on other sites More sharing options...
Polygon Posted June 5, 2011 Share Posted June 5, 2011 I've been wondering the same thing and I've seen this one suggested a lot. http://www.gpcperformance.com/Adams_Foam_Gun_p/483.htm?1=1&CartID=0 EDIT: Sorry, not a foam cannon. Link to comment Share on other sites More sharing options...
MacCool Posted June 5, 2011 Share Posted June 5, 2011 http://www.adamsforums.com/forums/showthread.php?t=11721 It's a good choice. Buy one of these and a 3/8 inch NPT brass pipe nipple. If you use 3/8 NPT quick-disconnects, you can easily switch between foam gun and rinse lance. Link to comment Share on other sites More sharing options...
scott5 Posted June 6, 2011 Share Posted June 6, 2011 I've been wondering the same thing and I've seen this one suggested a lot. http://www.gpcperformance.com/Adams_Foam_Gun_p/483.htm?1=1&CartID=0 EDIT: Sorry, not a foam cannon. i was looking at this the other day when i was there. What are the benefits of using a foam gun? Or no benefits, just makes its easier to wash the car? Never even heard of one of these before i got on this site. Link to comment Share on other sites More sharing options...
MacCool Posted June 6, 2011 Share Posted June 6, 2011 As is the point of any detergent, it loosens dirt/grime/bugs/bird droppings/etc and makes them more likely to be rinsed away rather than have to be scrubbed away. A foam gun allows an even application of detergent without scrubbing it on. Scrubbing = swirls. More scrubbing = more swirls. Link to comment Share on other sites More sharing options...
Billyt Posted June 6, 2011 Share Posted June 6, 2011 As is the point of any detergent, it loosens dirt/grime/bugs/bird droppings/etc and makes them more likely to be rinsed away rather than have to be scrubbed away. A foam gun allows an even application of detergent without scrubbing it on. Scrubbing = swirls. More scrubbing = more swirls.plus you can have 2 buckets of clean water to rinse the wash pads in. Just foam then let dwell for 10 minutes and rinse of and repeat but second time wash the car with mitt or pad. Link to comment Share on other sites More sharing options...
Z06Addict
8 answers to this question
