valente Posted June 23, 2011 Share Posted June 23, 2011 im doing the headlights with SHR and the 4"pads-using a drill. i have a question,is the SHR the only thing i need or should i use like the FMP and the MSW.sorry for the short post but im outside doing it right now Quote Link to comment Share on other sites More sharing options...
0 MAYBEN Posted June 23, 2011 Share Posted June 23, 2011 you want to follow up with the FMP.. MSW is suggested at the end to add some protection so they look like that longer.. Quote Link to comment Share on other sites More sharing options...
0 mc2hill Posted June 23, 2011 Share Posted June 23, 2011 ^Yep. Quote Link to comment Share on other sites More sharing options...
0 valente Posted June 23, 2011 Author Share Posted June 23, 2011 Sorry,i forgot i did not order the black pad for the MSW.im using the SSR the SHR and i gess im going to do the FMP,but i dont know if i can something else for the MSW.thank you Quote Link to comment Share on other sites More sharing options...
0 MAYBEN Posted June 23, 2011 Share Posted June 23, 2011 BW, or Americana will help.. Â if you have MSW you can apply it by hand, just make sure its thin.. Quote Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted June 23, 2011 Share Posted June 23, 2011 Good luck & post up some before & after pics! Quote Link to comment Share on other sites More sharing options...
0 valente Posted June 24, 2011 Author Share Posted June 24, 2011 heres the before #2 #3 after, #1 #2 they dont look as good as new but they look better. i just read on another post here that is good to use sand paper.im going to do this again in a couple of weeks and see if it helps,if not then im going to have to try somethng else.they do look better then before do:2thumbs: Quote Link to comment Share on other sites More sharing options...
0 MAYBEN Posted June 24, 2011 Share Posted June 24, 2011 big improvement.. if you did a couple more passes of SHR then FMP you may be able to knock that out.. Quote Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted June 24, 2011 Share Posted June 24, 2011 Nice save!!! Quote Link to comment Share on other sites More sharing options...
0 valente Posted June 24, 2011 Author Share Posted June 24, 2011 big improvement.. if you did a couple more passes of SHR then FMP you may be able to knock that out.. Im going to wait for a week,then i will try it again.thanks for the help Quote Link to comment Share on other sites More sharing options...
0 valente Posted June 24, 2011 Author Share Posted June 24, 2011 (edited) Nice save!!! thank you,i want to get the hang of using the pads before i touch the wifes challenger Edited June 24, 2011 by valente Quote Link to comment Share on other sites More sharing options...
0 mc2hill Posted June 24, 2011 Share Posted June 24, 2011 Nice job Daniel! Â i just read on another post here that is good to use sand paper.im going to do this again in a couple of weeks and see if it helps,if not then im going to have to try somethng else.they do look better then before do:2thumbs: Â Before you sand them look at them closely with the lights on, and (with the lights off) shine a strong light into them. Often the surface is as good as you can get it and the remaining defects are inside the housing. Quote Link to comment Share on other sites More sharing options...
0 valente Posted June 24, 2011 Author Share Posted June 24, 2011 Before you sand them look at them closely with the lights on, and (with the lights off) shine a strong light into them. Often the surface is as good as you can get it and the remaining defects are inside the housing. I think youre right,still im going to try it again and see what happens. there is a good Write up on the GPONA site that shows you what you need to do to open them up,but i dont think i can put mine in the oven.knowing me i would probably melt the sh**t out of them:o Quote Link to comment Share on other sites More sharing options...
0 the1inblue Posted June 24, 2011 Share Posted June 24, 2011 Good turn out. Word of advice, I wouldn't worry about the top of the headlights as they don't really have any effect on the clarity of the light. Second as said before I turned the headlights on before you're finish. This will help find spots that need another pass. Also when the lights are on you may see small scratches or chip looking marks. Well those are just normal wear and tear. Polishing them isn't gonna fixed that. Overall a very good job. Sent from my DROIDX using Tapatalk Quote Link to comment Share on other sites More sharing options...
0 valente Posted June 25, 2011 Author Share Posted June 25, 2011 They do look way better than before.so im happy now,but im still going to go at them next week.thanks again Quote Link to comment Share on other sites More sharing options...
0 Doug123 Posted June 25, 2011 Share Posted June 25, 2011 And put the hood up if you are working on those top edges - Quote Link to comment Share on other sites More sharing options...
valente
15 answers to this question
