When using the FMP & pad I am seeing tiny specs of the pad flaking off. Inspecting the pad, it looks fine but when in use I can see the specs flying off.
Is this normal, a bad pad or am I doing something wrong?
I am using the PC on a setting of 6. I was trying to follow Junkman2008's video by using a setting of 5 but if I apply 14lbs of pressure the pad stops spinning. I even got a scale out and tested this and at 13-14 lbs it stops spinning. I have found comments saying the speed difference between setting 5 and 6 is small or unnoticeable but on the PC I have it seems like it easily doubles the speed. I wasn't really getting great results on setting 5.
Pyrophor2011
17 answers to this question
