csrt4 Posted September 9, 2011 Share Posted September 9, 2011 Hi, I would like to know, how do I know when is it necessary to take a new pad? When I polish a car and I don't have enought pads to do a complete job, there's a way you clean the pad to continue using it? Thanks, Steve Link to comment Share on other sites More sharing options...
TK427 Posted September 9, 2011 Share Posted September 9, 2011 Pretty sure that when you clean your pads, they must be fully dry before you can use them again. Link to comment Share on other sites More sharing options...
Chris@Adams Posted September 9, 2011 Share Posted September 9, 2011 Once you clean your pads it takes a couple of days to dry, its nice to have a couple of each color pads available to use. Link to comment Share on other sites More sharing options...
csrt4 Posted September 9, 2011 Author Share Posted September 9, 2011 Hi, I know that the pad take some days to dry and I must use a dry pad, but, I would like to know, how do I know when is it necessary to take a new pad? For a normal car, (swirl and hase remover and fine machine polish), normally, how much pads of each I need ? Steve Link to comment Share on other sites More sharing options...
TK427 Posted September 10, 2011 Share Posted September 10, 2011 I'm still using my first set aka origanal pads that I bought two mounths ago! Go to the JunkMan's corner in the Adams Forum and watch his ViD's..Save You Some Duh.. Link to comment Share on other sites More sharing options...
Captain Slow Posted September 10, 2011 Share Posted September 10, 2011 Steve, I've been in this situation before myself. I used a microfiber towel held in one hand pushing against the pad while the polisher is running on low speed. This transfers some of the surface junk on to the towel. See below: <iframe src="http://www.youtube.com/embed/M24NiGvBRgQ" allowfullscreen="" frameborder="0" height="345" width="420"></iframe> Does it make it spotless? Nope. Does it allow you to maybe finish the job today? Possibly. Just like one can never have too many MF towels one can also never have too many pads; lesson learned. BTW: Some people use a hard nylon brush to clean their pads during a correction. I can't make myself put something that hard on a pad that is going to touch my paint. As for when to change the pad, I change it when the pad is visibly dirty. If the pad I'm using should be orange and it's looking closer to yellow or white then it is definitely time to swap for a clean pad. Same with the white pad. If it's looking grey or yellow it comes off and a new goes on. Finally, always take more pads and MF towels than you think you'll need to do the job. Link to comment Share on other sites More sharing options...
csrt4 Posted September 10, 2011 Author Share Posted September 10, 2011 Steve, I've been in this situation before myself. I used a microfiber towel held in one hand pushing against the pad while the polisher is running on low speed. This transfers some of the surface junk on to the towel. See below: <IFRAME height=345 src="http://www.youtube.com/embed/M24NiGvBRgQ" frameBorder=0 width=420 allowfullscreen=""></IFRAME> Does it make it spotless? Nope. Does it allow you to maybe finish the job today? Possibly. Just like one can never have too many MF towels one can also never have too many pads; lesson learned. BTW: Some people use a hard nylon brush to clean their pads during a correction. I can't make myself put something that hard on a pad that is going to touch my paint. As for when to change the pad, I change it when the pad is visibly dirty. If the pad I'm using should be orange and it's looking closer to yellow or white then it is definitely time to swap for a clean pad. Same with the white pad. If it's looking grey or yellow it comes off and a new goes on. Finally, always take more pads and MF towels than you think you'll need to do the job. Thanks for your answer. A old microfiber can do the job . Link to comment Share on other sites More sharing options...
chrisguga Posted September 10, 2011 Share Posted September 10, 2011 I like to use a fairly stiff bristled brush with the PC spinning on 3 to clear the pad. I use an extra wheel brush that is clean and only used for clearing pads. Link to comment Share on other sites More sharing options...
csrt4
Hi,
Thanks,
Steve
