J-Will Posted September 19, 2011 Share Posted September 19, 2011 Hi guys, I’ve been periodically reading through the forum and finally decided to join. I recently obtained my father’s 1995 Ford Mustang GT Convertible. It has a 5.0 v8. Its black on black, and everything is stock (by everything, I mean the first thing I did was replace the tires… not because of low tread, but because they were 15 years old!). I have been slowly doing a minor maintenance overhaul on the car, as it has basically sat for several years (fluid flushes, and filter replacements etc.). She only has 26k on the clock. It’s been garage kept, and will continue to be.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com<img src=" /><o:p></o:p> Link to comment Share on other sites More sharing options...
J-Will Posted September 19, 2011 Author Share Posted September 19, 2011 The reason I joined is because while the car is clean, the engine is running great, the paint minor blemishes. Some swirl marks here and there, and some slight scratches. As I’ve learned from this forum and Adam’s videos- they are probably from previous washings. I am no too worried about those, as wax does a good job of covering them up, so I know these polishes will. I am however worried about this (looks like clear coat bubbles, but I want it gone): Link to comment Share on other sites More sharing options...
70'sChevyGirl Posted September 19, 2011 Share Posted September 19, 2011 :hi: Its nice that you have your dad's car and that it was garage kept for many years. Link to comment Share on other sites More sharing options...
J-Will Posted September 19, 2011 Author Share Posted September 19, 2011 Its nice that you have your dad's car and that it was garage kept for many years. Thanks' date=' its always been garage kept, which is my concern over whatever that bubbling is. I need to clean up under the hood some, but thats where the work is taking place so there isnt much point right now. As I said, its bone stock, and that is the way it'll remain... maybe Since the car sat for so long I have taken some precautions: [list'] [*]New tires (that was a must) [*]Trans flush - actually performed twice due to torque converter chatter. My thought was all the trans fluid sunk to the bottom from gravity and lack of use/ circulation. Two flushes were performed in an attempt to get all the old fluid out and completely replaced with new. Converter chatter was gone by the time the car was backed out of the driveway [*]Engine power flush - very slight tick IMO was from a valve (though could have been trans related due to the above issue). Also, it had been over a year (though only 50 miles) since the last oil change. This fluch was more than likely not necessary. Either way, the engine flush was performed and the tick was no more. [*]Oil change - no brainer here, though blended synth was used [*]Seafoam treatment - poured and sprayed in intake manifold, gas, and brake booster. Will add to crankcase just before oil change. I love this stuff Winter is almost here and the car will spend many months in the garage. Though it will not be neglected. I plan to perform more work over the "break from good weather" Minor tune up replacing spark plugs, wire, ditributer cap and rotor Engine Intake flush - probably not needed, but again because the car sat I am leaning toward the side of caution in order to prevent any build up. Seafoam also helps with this Probably replace some more minor things that probably dont need it yet: drive belt, fuel filter, PCV valve etc Of course start an Adam's polishes regiment in order to bring out the black gloss even more. I really want that small section of bubbling gone. So any advice there would be greateful. Link to comment Share on other sites More sharing options...
Chris@Adams Posted September 19, 2011 Share Posted September 19, 2011 Josh! Link to comment Share on other sites More sharing options...
StormChaser Posted September 19, 2011 Share Posted September 19, 2011 Welcome to the family Josh! Link to comment Share on other sites More sharing options...
MichiganSRT8 Posted September 19, 2011 Share Posted September 19, 2011 , from one josh to another that stang looks great, Im sure with all the products Adam's offers you will have it all squared away soon! Link to comment Share on other sites More sharing options...
694doorbird Posted September 19, 2011 Share Posted September 19, 2011 to the club!!! Hard to tell, but it does look like the clear coat is bubbling up. Hopefully one of the experts will see your question about it. Link to comment Share on other sites More sharing options...
J-Will Posted September 20, 2011 Author Share Posted September 20, 2011 Thanks everyone, just trying to figure out what I need for the vehicle's paint revival Link to comment Share on other sites More sharing options...
eric@thompsonracing.us Posted September 20, 2011 Share Posted September 20, 2011 Sounds like you need to attend this clinic: http://www.adamsforums.com/forums/upcoming-detail-clinics/13824.htm Link to comment Share on other sites More sharing options...
J-Will Posted September 20, 2011 Author Share Posted September 20, 2011 Sounds like you need to attend this clinic: http://www.adamsforums.com/forums/upcoming-detail-clinics/13824.htm A clinic would help; I will try to make it up there for it. Thanks for the heads up. Link to comment Share on other sites More sharing options...
Odds and Ends Posted September 20, 2011 Share Posted September 20, 2011 Welcome to the forums, Josh....PM sent! - Darryl Link to comment Share on other sites More sharing options...
MAYBEN Posted September 20, 2011 Share Posted September 20, 2011 Welcome Josh! Link to comment Share on other sites More sharing options...
J-Will Posted September 20, 2011 Author Share Posted September 20, 2011 Thanks for the warm welcomes... I can tell this is going to be a fun 'paint beautification' winter Link to comment Share on other sites More sharing options...
pjwoolw Posted September 22, 2011 Share Posted September 22, 2011 Welcome aboard Josh! Link to comment Share on other sites More sharing options...
