4" Pad Question
07RS4
Posted
Ok people...so I finally got the PC about a week ago. As you know I cleaned the interior to near perfection this past weekend, then I did the Clay, APC, Iron Cut, APC wash again to prep for the Polish. I also, did the undercarriage painting that I asked about a few months ago (I'll post pics in due time). But now I'm in to polishing.
Here is my first question...I have more, but the wife is calling me to eat dinner, haha.
1. I'm using the 4" pads on the front quarters because, well there just easier to manuever in the tights spaces. My question is this. I have the setting on four....Is the pad supposed to be spinning, or not at all? Which gets the best results? I tried both ways, and I see similiar results so far...
I ask, because in the video, Adam says that you need a slight rotation to get the correction you want, but I also found a post that Dylan said it shouldn't be spinning at all.
Thoughts please before I start another panel tonight. THANK YOU!
4 answers to this question
Posted
It'll be virtually impossible to stop such a small pad from spinning at all without putting down a TON of pressure so you'll see some spinning... thats normal. Just use about the same amount of pressure you'd use on the full size pads. Doesn't take much.
Posted
i believe there is a process they were refering to as scrubbing, where you use as much force to get the pad to not spin and you do the work, however I know Junkman was saying it takes alot and you have to be careful, also it eats pads.
Posted
Got it sir. Thank you!
