GTAHVIT Posted October 28, 2011 Posted October 28, 2011 Ok... I've got a coat of BG on the car now. I'm thinking about laying down some MSW/S ... Question 1: Do I need to get the BG off the car before I do start the MSW/S? Question 2: After the MSW/S has cured, can I then reapply the BG followed by BW. If so is there any cure time for the BG before I apply the wax? Thanks guys.
Chewy Posted October 28, 2011 Posted October 28, 2011 Do a IPA wipe down and then apply MSS. After 12-24 hours, apply BG and top!
Team Adam's Posted October 28, 2011 Posted October 28, 2011 yes, remove the glaze before applying the MSS for best results. As a sealant MSS will perform best when applied to bare paint. The glaze will significantly shorten its life span if its under there. Your order is always: SEALANT GLAZE WAX You can do all 3 or any combination so long as the order of application stays the same.
GTAHVIT Posted October 28, 2011 Author Posted October 28, 2011 Cool! OK so, once the MSS has cured I can wipe it down with WW or DS right?
Doug123 Posted October 28, 2011 Posted October 28, 2011 And if you do MSS BG Americana it looks Niiice and is very rugged.
jayhuffdaddy Posted November 17, 2011 Posted November 17, 2011 yes, remove the glaze before applying the MSS for best results. As a sealant MSS will perform best when applied to bare paint. The glaze will significantly shorten its life span if its under there. Your order is always: SEALANT GLAZE WAX You can do all 3 or any combination so long as the order of application stays the same. And polish before sealant correct?
Chris@Adams Posted November 17, 2011 Posted November 17, 2011 And polish before sealant correct? Correct, always polish first!
jayhuffdaddy Posted November 22, 2011 Posted November 22, 2011 Can the Machine Super Sealant be applied to my clear bra with the PC? If so I intend on using blue painters tape for the edge.
GTAHVIT
Ok...
Question 1:
Question 2:
Thanks guys.
9 answers to this question
