FINISHING TOUCH Posted December 1, 2011 Share Posted December 1, 2011 Can I use a rotary buffer with S&H. If so does Adams sell pads for the rotary buffer Link to comment Share on other sites More sharing options...
07RS4 Posted December 1, 2011 Share Posted December 1, 2011 Can I use a rotary buffer with S&H. If so does Adams sell pads for the rotary buffer They are working on the pads for the rotaries, last I heard from Dylan is sometime next year. I hope that you can use the SHR and FMP with the rotaries, because a little birdie told me I have a Flex 150-2 wrapped under the tree:lolsmack: Link to comment Share on other sites More sharing options...
3PedalMINI Posted December 1, 2011 Share Posted December 1, 2011 because a little birdie told me I have a Flex 150-2 wrapped under the tree:lolsmack: you mean your credit card statement right? with the exact place and price of what you told your wife when she asked you what you wanted for christmas... Link to comment Share on other sites More sharing options...
07RS4 Posted December 1, 2011 Share Posted December 1, 2011 you mean your credit card statement right? with the exact place and price of what you told your wife when she asked you what you wanted for christmas... Bwahahaha, exactly Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted December 1, 2011 Share Posted December 1, 2011 I would say yes...as for the pads just buy a rotary backing plate that will fit the adams pads. As of right now the PC pads would be your best bet bc the way they're designed. The raised foam will generate less heat compared to the The Flex pads. Flex pads being flat could make the surface your working extremly hot and burn the paint. I think these are the new pads they are designing for rotary buffers. Post #8 http://www.adamsforums.com/forums/company-info-announcements/14908.htm Link to comment Share on other sites More sharing options...
07RS4 Posted December 1, 2011 Share Posted December 1, 2011 I would say yes...as for the pads just buy a rotary backing plate that will fit the adams pads. As of right now the PC pads would be your best bet bc the way they're designed. The raised foam will generate less heat compared to the The Flex pads. Flex pads being flat could make the surface your working extremly hot and burn the paint. I think these are the new pads they are designing for rotary buffers. Post #8 http://www.adamsforums.com/forums/company-info-announcements/14908.htm Those are the Flex 3401 DA pads that they are testing. I'm not sure if they are the same ones intended for the rotary. Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted December 1, 2011 Share Posted December 1, 2011 Those are the Flex 3401 DA pads that they are testing. I'm not sure if they are the same ones intended for the rotary. yes...but im assuming the rotary pads would look similar to those. Link to comment Share on other sites More sharing options...
07RS4 Posted December 1, 2011 Share Posted December 1, 2011 yes...but im assuming the rotary pads would look similar to those. Yeah, your probably right. Link to comment Share on other sites More sharing options...
FINISHING TOUCH
