Fit08 Posted April 28, 2012 Share Posted April 28, 2012 Any one have/found solution for attaching foam cannon to simoniz gas power washer? This seems to be an issue I hear. Link to comment Share on other sites More sharing options...
07RS4 Posted April 28, 2012 Share Posted April 28, 2012 Any one have/found solution for attaching foam cannon to simoniz gas power washer? This seems to be an issue I hear. Eaziest solution to all gas powered and electric pressure washers? Adapt your nozzle end of your spray wand to a quick disconnect. The foam cannon comes with a QD, and it will be much easier in the end. I just picked up this electric pressure washer last sunday and that's what I did. Electric Pressure Washer from Cleanforce | The Home Depot - Model CF1800HD One thing to note, not all female QD's are created equal. Some have different depths. The QD that came with the PW wouldn't seat properly, so I had to get a higher rated one that was a little deeper. Hopefully that makes sense. Link to comment Share on other sites More sharing options...
Fit08
1 answer to this question
