Stevert Posted June 15, 2012 Share Posted June 15, 2012 Can i apply the revive polish with a polish pad and a PC buffer? Or will I be causing damage? Link to comment Share on other sites More sharing options...
0 JBlack151 Posted June 15, 2012 Share Posted June 15, 2012 You sure can. Revive can be used with the Adam's Machine Super Sealant & Wax Pad Here is a thread with a little more detail to explain. Don't forget you can also apply Adam's Buttery Car Wax with the same pad as well. http://www.adamsforums.com/forums/machine-polishing/18346.htm Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted June 15, 2012 Share Posted June 15, 2012 You can but Revive is mainly a hand polish, FMP would be the go to machine polish. Link to comment Share on other sites More sharing options...
0 egott_91 Posted June 15, 2012 Share Posted June 15, 2012 Revive, I have found, is much easier to use by hand than with a Machine. Link to comment Share on other sites More sharing options...
0 THE Mook Posted June 15, 2012 Share Posted June 15, 2012 Welcome! Revive Hand Polish can be used for a multitude of things, and machine application is one of them. If you are going to be using a Porter Cable Polisher with the Revive, we recommend a Black 7" Pad, and Speed 3. Mook Link to comment Share on other sites More sharing options...
0 JBlack151 Posted June 15, 2012 Share Posted June 15, 2012 If you are going to be using a Porter Cable Polisher with the Revive, we recommend a Black 7" Pad, and Speed 3. Very good tip right there. Thanks Mook. I was playing around with different speeds on the PC with the Revive last week and wasn't liking anything above 3 when I first tried it (tried 4 and 5). Good to know that's what's recommended Link to comment Share on other sites More sharing options...
0 Mick Posted June 15, 2012 Share Posted June 15, 2012 Are you talking about the blue revive? I still have a small amount of the tan revive left. Link to comment Share on other sites More sharing options...
Stevert
6 answers to this question
