Wardo Posted July 25, 2012 Share Posted July 25, 2012 Took the truck up to the mountains this past weekend plus it's been rain and dust storm city here for a few weeks. I planned on the normal 2 bucket, extra time on the first spray down. Then probably a super thick bubble bath with the foam gun. Is there anything else I should do, to avoid damage. tap a talka thingy Link to comment Share on other sites More sharing options...
0 Team Adam's Posted July 25, 2012 Share Posted July 25, 2012 Rinse well and clean your pad frequently. That should be all you need to do, you can also add a 3rd bucket and grit guard. I've found when very dirty my soap bucket was still getting grit b/c the rinse bucket would become so contaminated. http://www.adamsforums.com/forums/wash-dry-clay-bar/17701.htm Link to comment Share on other sites More sharing options...
0 Wardo Posted July 25, 2012 Author Share Posted July 25, 2012 Good idea, I have a third bucket but only one grit gaurd. It's giving me nightmares thinking about scratching up the corrected paint. Lol I'm sure that is everyone's worst thought on this forum tap a talka thingy Link to comment Share on other sites More sharing options...
0 MAYBEN Posted July 25, 2012 Share Posted July 25, 2012 that Tahoe/Suburban is done for, better send it to me, I'll clean and drive it.. Link to comment Share on other sites More sharing options...
0 Osok Posted July 26, 2012 Share Posted July 26, 2012 That kind of grime usually leads me to a strip wash. I sometimes find just regular straight Adams car shampoo isn't aggressive enough to take some nasty film type dirt off. Of course if you strip wash it means a rewax aftewards though. Link to comment Share on other sites More sharing options...
0 koebot Posted July 26, 2012 Share Posted July 26, 2012 That's how my car looks after winter. I two bucket wash it… twice. Keep the wash pad clean. Probably empty and refill the buckets half way through. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted July 26, 2012 Share Posted July 26, 2012 Instead of using a foam gun I spray down with WW, it makes the surface super slick. Less friction = less chance of scratching! Link to comment Share on other sites More sharing options...
0 colodude18 Posted July 26, 2012 Share Posted July 26, 2012 Whenever I have driven in the rain, meaning the car is covered with sand and grime, I go to the coin car wash and power wash the vehicle down with high pressure soap. I DON'T RINSE to prevent water spots, drive home and do my 2-bucket wash. Power washing first takes off 90% of the muck in my experience. Reason I go to the car wash is their water is hot and has soap in it. Also the pressure is better than when using a non-professional power washer at home... Link to comment Share on other sites More sharing options...
0 ExpressThis13 Posted July 27, 2012 Share Posted July 27, 2012 Whenever I have driven in the rain, meaning the car is covered with sand and grime, I go to the coin car wash and power wash the vehicle down with high pressure soap. I DON'T RINSE to prevent water spots, drive home and do my 2-bucket wash. Power washing first takes off 90% of the muck in my experience. Reason I go to the car wash is their water is hot and has soap in it. Also the pressure is better than when using a non-professional power washer at home... I was just going to suggest this but you beat me to it. When your car is that nasty I think spending a couple bucks at the car wash to blast off with a high pressure washer is well worth it to me just my 2 cents. Link to comment Share on other sites More sharing options...
0 ChargerMatt Posted July 27, 2012 Share Posted July 27, 2012 Take it to a coin op and pressure wash it first, then take it home to wash. Link to comment Share on other sites More sharing options...
0 Vink70 Posted July 27, 2012 Share Posted July 27, 2012 I ALWAYS pressure wash before I do my two bucket wash. Pretty much no matter what. I noticed my buckets still get some dirt in them but not nearly as much as if I didnt pressure wash it. That is exactly what yours needs. Link to comment Share on other sites More sharing options...
0 JJ Stin Posted July 30, 2012 Share Posted July 30, 2012 Take it to a coin op and pressure wash it first, then take it home to wash. Thats what I usually do. Link to comment Share on other sites More sharing options...
0 Jonothon Posted July 30, 2012 Share Posted July 30, 2012 I'm confused because I thought the whole point in washing was to lift the dirt from the finish to prevent finish damage? Could it might be better to spray down the car/truck with waterless wash then foam it, let it set then use your hose to rinse it off? Link to comment Share on other sites More sharing options...
0 BlueGenCoupe Posted July 30, 2012 Share Posted July 30, 2012 Take it to a coin op and pressure wash it first, then take it home to wash. I always pressure wash my car prior to washing. Get all the big heavy stuff off before it does damage Link to comment Share on other sites More sharing options...
Wardo
tap a talka thingy
13 answers to this question
