13-Mustang-GT/CS Posted May 25, 2013 Share Posted May 25, 2013 Once applied to a panel, how long does it take to haze up and ready for removal. Also what would happen if I left it on a panel too long. On the other hand, what would happen if I removed the wax too soon? Link to comment Share on other sites More sharing options...
0 GerryC Posted May 25, 2013 Share Posted May 25, 2013 Americana is ready to remove within a minute or so. Just make sure to apply it thin. If you leave it on too long (say over 10 minutes), the residue will harden and will become difficult to remove without significant effort, so take your time and ensure all the residue is wiped off. Since it dries pretty quick, I don't think it is possible to remove Americana "too soon". Because of all this, rather than doing the entire car, apply to only one or two panels at a time (ideally in the shade while the surface is cool), wipe off the residue, and then do one or two more. Compared to a liquid wax like BW, t takes a little more time and requires a bit of extra attention, but the results and protection qualities are totally worth it. THE Mook 1 Link to comment Share on other sites More sharing options...
0 BKazzle Posted May 25, 2013 Share Posted May 25, 2013 (edited) It usually hazes up for me after I've done 1-2 more panels. So I do 3 panels (depends on vehicle size), then to back and wipe off the first one I did. (Recommended by Adam's team) Usually if you let a wax sit for too long then it becomes way harder to remove, thus making it easier for your shiny paint to get marred because you're wiping harder. If you wipe it off too soon then I'm going to guess that it didn't have time to seat itself on top of clear/sealant/glaze. You can do the "finger swipe" test to make sure if you want. Let the wax sit and when you think it hazed up enough, wipe your finger across the panel (6 inches or so) and if the paint looks clear and perfect where you wiped then it's ready to come off; if it looks greasy still, then it needs to settle more. The finger swipe test should work for all sealants and waxes, but not entirely sure about that. The Adam's team knows their product better than anyone and I'm sure will chime in here. Edit: Gerry makes a good point. Americana probably can't be wiped off too soon. Edited May 25, 2013 by BKazzle Link to comment Share on other sites More sharing options...
0 GerryC Posted May 25, 2013 Share Posted May 25, 2013 The finger swipe method is great for seeing if your LSP is ready for removal but I prefer to use a corner of a MF towel THE Mook 1 Link to comment Share on other sites More sharing options...
0 BKazzle Posted May 25, 2013 Share Posted May 25, 2013 Probably a better alternative. I forgot to tell you though: I had my finger tips surgically removed and replaced with double soft MF towel. Captain Slow, GerryC and THE Mook 3 Link to comment Share on other sites More sharing options...
0 13-Mustang-GT/CS Posted May 26, 2013 Author Share Posted May 26, 2013 Alright thanks for the input guys. I just figurer I ask this question because last time I waxed my car i used meg's nxt2.0 and it took about 30-40 min to haze up and when i did my car the other day with americana, i gave it about 20 min and it was hard to remove. My guess was that I let it sit too long. Also i do not have access to a garage, so when i am doing my detailing sometimes it is in the sun for a little. How does the sun effect the process of laying down a coat of americana? Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted May 26, 2013 Share Posted May 26, 2013 When I work in my garage , I will do no more than two panels at a time, If I am working outside at a show I may just do a third of a panel before I wipe off........so it depends on if you are in the shade or sun...etc. Link to comment Share on other sites More sharing options...
13-Mustang-GT/CS
6 answers to this question
